StarTech.com Network Cable Stripper/Cutter
Quicklinx: J4L7WS00 Mfr#: CABLESTRIPCUT
17 In Stock
£9.03 ex VAT
£10.83 inc VAT
This portable Rotary Cable Stripper quickly and easily removes insulation from a variety of cables, making it an essential tool for network, coaxial, and multi-conductor cable preparation. This cable stripping tool features an easy-to-use design that enables effortless removal of cable jackets and insulation. With its 360-degree rotation, it ensures precise control, reducing hand strain during repetitive tasks. The tool fits cables with an outer diameter ranging from 3.5mm (0.13in) to 7.5mm (0.29in), making it ideal for various types of cables including UTP, FTP, STP, coaxial, and multi-conductor cables. Designed for use with a diverse range of cable types, this Network Cable Stripper features specific slots for both round and flat cables. It helps streamline your workflow by efficiently preparing coaxial, network, and audio cables for installation, making it an ideal tool for any professional or DIY project. This Cable Stripping and Cutting Tool allows you to adjust the clamping depth using a Phillips head screw to accommodate different cable thicknesses. This ensures precise insulation removal without damaging internal conductors. The built-in cutting slot enables you to neatly trim cable lengths, eliminating the need for additional cutting tools.
  • Easy-To-Use
  • Versatile Compatibility for Various Cables
  • Adjustable Depth & Integrated Cutter
StarTech.com Network Cable Stripper and Cutter, Wire Stripping Tool - cable cutter/stripper tool
Cable cutter/stripper tool
4.5 cm x 11 cm x 1.5 cm
45 g
Product Material
ABS plastic
Grey
Product Material
ABS plastic
4.5 cm
11 cm
1.5 cm
45 g
Enclosure Colour
Grey
Adjustable clamp, cutter
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
1.8 cm
Shipping Weight
49 g
50 °C
30 - 70%
Type: Cable cutter/stripper tool
