This USB-C multiport adapter supports 4K 30Hz HDMI or 1080p VGA and turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI or 1080p VGA video output, two USB 3.1 Gen 1 Type-A (5Gbps) ports (including 1x Fast Charge port), a single USB 3.1 Gen 1 Type-C (5Gbps) port, an SD/MicroSD card reader and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 1 (5Gbps) is also known as USB 3.2 Gen 1 (5Gbps) and USB 3.0 (5Gbps).
Enhance Productivity
The portable docking station offers versatile video flexibility by connecting your laptop to a 4K 30Hz HDMI monitor (4096 x 2160p) or a 1080p (60Hz) VGA monitor (1920x1080) to create a powerful workstation. For added video flexibility, the dock also supports ultra-wide monitors. -
Connect Your Devices
The USB-C to USB 3.1 Gen 1 hub gives you two USB-A (5Gbps) ports and one USB-C (5Gpbs) port to connect your USB devices. -
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards. -
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop when a power adapter is connected to the USB-C power input port. Plus, one of the USB-A (5Gbps) ports supports BC 1.2 fast charge to power your peripherals when the dock is connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB, Ethernet and video disruption when you switch power sources (USB-C power adapter to bus power). -
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access with support for PXE Boot and WoL.
- StarTech.com USB C Multiport Adapter, HDMI 4K 30Hz or VGA Travel Dock, 5Gbps USB 3.0 Hub (USB A / USB C Ports), 100W Power Delivery, SD/MicroSD Slot, GbE, 12" (30cm) Long Attached Cable - USB C Mini Dock - docking station - USB-C 3.2 Gen 1 - HDMI, VGA - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C 3.2 Gen 1
- Video Interfaces
- HDMI, VGA
- 5.9 cm x 1.4 cm
- 137 g
- Space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 5.9 cm
- 1.4 cm
- 137 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 4096 x 2160 - 30 Hz (HDMI only) , 1920 x 1080 - 60 Hz (VGA only)
- Data Link Protocol
- USB 3.0, USB 3.1 Gen 1, USB 3.2 Gen 1, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Slots
- 1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C , 1 x network - 1000Base-T - RJ-45
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery, DisplayPort Alt Mode, Preboot Execution Environment (PXE) support, wake on LAN, full duplex support
- USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), FCC, RoHS
- OS Required
- Apple MacOS X 10.9 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS
- Limited warranty - 3 years
- Shipping Width
- 11 cm
- Shipping Depth
- 5.9 cm
- Shipping Height
- 1.4 cm
- Shipping Weight
- 204 g
- 0 °C
- 45 °C
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.41 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.63 |
