Share an HDMI display between multiple analog or digital video sources (e.g. VGA, Component, S-Video, Composite, HDMI). The VS721MULTI Multiple Video Input to HDMI Switcher enables users to switch between 7 different audio-video sources to a single HDMI-equipped display.
This versatile scaler/switcher is the perfect solution for combining and scaling analog video sources (RGB/YPbPr/YCbCr) with your digital HDMI display, eliminating the cost of upgrading individual components (i.e. DVD player, PC, VCR, etc.).
An all-in-one multimedia solution, the video converter/switcher includes support for full high definition 1080p video resolution as well as digital and analog audio. Plus, the switch features RS232 remote serial control, and includes a convenient IR remote control for switching between video sources.
- StarTech.com Multiple Video Input to HDMI Switcher - HDMI / VGA / Component (VS721MULTI) - video/audio switch - 7 ports
- Video/audio switch - 7 ports
- Subtype
- HDMI / component video / S-Video / VGA /audio
- HDCP compliant
- Power
- AC 120/230 V
- 17.3 cm x 38.4 cm x 4.5 cm
- 1.8 kg
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7 / 8, Windows 10 (32/64 bits)
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- Max Resolution
- 1920 x 1200
- HDCP compliant
- 1 x component video input RCA x 3 , 1 x VGA input HD-15 , 3 x HDMI input , 1 x composite video input RCA , Audio / video: 3 x RCA , 1 x audio input mini-jack , Video: 1 x S-video input , 1 x HDMI output , 1 x serial (RS-232) DB-9
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Included Accessories
- Remote control
- Cables Included
- 1 x serial cable
- Mounting Kit
- Included
- FCC, RoHS
- Localisation
- OS Required
- 17.3 cm
- 38.4 cm
- 4.5 cm
- 1.8 kg
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub | In Stock | £157.19 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
