StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub
Quicklinx: 9FSXWS00 Mfr#: MSTMDP123DP
25 in stock
£79.23 ex VAT
£95.07 inc VAT
Use this multi-stream transport hub to connect three DP monitors to a single mDP 1.2 port. This MST hub lets you connect three monitors to your Mini DisplayPort (mDP) 1.2 equipped Windows tablet, laptop or desktop.
The hub has been rigorously tested to ensure compatibility with the Microsoft Surface Pro 4, Surface Pro 3 and Surface Book.
Please note Microsoft Surface products only supports the use of three displays in total. If more than three external monitors are attached, the built-in touch screen on your Surface will be disabled. If four monitors are attached, the fourth monitor will not display any content.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use Mini DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures that your MST hub will be compatible with virtually any television, monitor or projector. The hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
When using a DisplayPort 1.1 video card the MSTMDP123DP will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTMDP123DP supports plug-and-play installation for a hassle-free setup.
StarTech.com Mini DisplayPort to DP Multi Monitor Splitter - 3-Port MST Hub - video splitter - 3 ports
Video splitter - 3 ports
Ports
3 x DisplayPort
AC 100/230 V
7.8 cm x 2 cm x 20 cm
95 g
Enclosure Type
Desktop
Ports
3 x DisplayPort
Max Resolution
2560 x 1600
3 x DisplayPort , 1 x mini-DisplayPort
External power adapter
AC 100/230 V
FCC, RoHS
7.8 cm
2 cm
20 cm
95 g
45 °C
9FSX StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £15.23
9FSX StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £11.08
9FSX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
9FSX StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
9FSX StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £26.71
9FSX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £22.13
9FSX StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.10
9FSX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.20
9FSX StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
9FSX StarTech.com DisplayPort to DVI Active Adapter In Stock £21.76
9FSX StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £17.42
9FSX StarTech.com DC Power Adapter - 5V, 3A In Stock £12.19
Price Range Ex VAT: 50 - 100
