StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub
Quicklinx: 9FSXWS00 Mfr#: MSTMDP123DP
£46.65 ex VAT
£55.98 inc VAT
Use this multi-stream transport hub to connect three DP monitors to a single mDP 1.2 port. This MST hub lets you connect three monitors to your Mini DisplayPort (mDP) 1.2 equipped Windows tablet, laptop or desktop.
The hub has been rigorously tested to ensure compatibility with the Microsoft Surface Pro 4, Surface Pro 3 and Surface Book.
Please note Microsoft Surface products only supports the use of three displays in total. If more than three external monitors are attached, the built-in touch screen on your Surface will be disabled. If four monitors are attached, the fourth monitor will not display any content.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use Mini DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures that your MST hub will be compatible with virtually any television, monitor or projector. The hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
When using a DisplayPort 1.1 video card the MSTMDP123DP will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTMDP123DP supports plug-and-play installation for a hassle-free setup.
  • Increase your productivity with multiple monitors
    The newest generations of laptops are more portable than ever, unfortunately this means you're left with fewer video outputs and a small integrated screen. The MST hub solves these problems by letting you connect three independent displays to a single mDP port on your computer, which makes multitasking much easier. Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, which makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot desk solution with a wireless keyboard and mouse peripheral set. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
  • Astonishing picture quality that won't drain your system resources
    MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and medical imaging.
  • Works with any monitor, television or projector
    With this MST hub, you can use separate mDP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors. The hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment. The MSTMDP123DP has been certified by Microsoft and tested for compatibility with your Microsoft Surface Pro 3, Surface Pro 4 and Surface Book and is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com 3-Port Multi Monitor Adapter, Mini DisplayPort 1.2 to 3x DisplayPort MST Hub, Triple 1080p or Dual 4K 30Hz, mDP to DP MST Video Splitter for Extended Desktop on Windows PCs - Multi Stream Transport (MSTMDP123DP) - video splitter - 3 ports
Video splitter - 3 ports
Ports
3 x DisplayPort
AC 100/230 V
7.8 cm x 2 cm x 20 cm
95 g
3-year warranty
P/N: SVA5N3NEUA
Enclosure Type
Desktop
Ports
3 x DisplayPort
Max Resolution
2560 x 1600
3 x DisplayPort , 1 x mini-DisplayPort
External power adapter
AC 100/230 V
FCC, RoHS
7.8 cm
2 cm
20 cm
95 g
Limited warranty - 3 years
45 °C
P/N: SVA5N3NEUA
9FSX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.76
9FSX StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.60
9FSX StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £21.83
9FSX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £20.51
9FSX StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
9FSX StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.15
9FSX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £14.65
9FSX StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.35
9FSX StarTech.com DisplayPort to DVI Active Adapter In Stock £20.81
9FSX StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.12
9FSX StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £53.05
9FSX StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £46.65
9FSX StarTech.com MST Hub - mDP to 2x DP In Stock £34.23
9FSX StarTech.com MST Hub - 4-Port DisplayPort In Stock £65.23
9FSX StarTech.com MST Hub - 2-Port DisplayPort In Stock £40.09
9FSX StarTech.com DisplayPort to 3x HDMI MST Hub In Stock £66.38
9FSX StarTech.com mDP 1.2 to HDMI MST Hub In Stock £33.29
9FSX StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £38.47
9FSX StarTech.com DC Power Adapter - 5V, 3A In Stock £12.25
9FSX StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £52.56
9FSX StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.54
9FSX StarTech.com DP 1.4 to Dual HDMI MST Hub In Stock £31.56
