StarTech.com Multi-Input HDBaseT Extender
Quicklinx: DTP4WS00 Mfr#: ST121HDBTSC
£510.03 ex VAT
£612.03 inc VAT
Connect four video sources to a remote HDMI display over CAT5/CAT6 cabling, and easily scale and switch between HDMI, DP or VGA video sources. This multi-input HDBaseT extender kit extends your A/V signals to a remote location up to 230 ft. (70 m) away. It features a built-in switch and scaler, so you can choose which video source is output from four independent video sources (2 x HDMI, 1 x VGA and 1 x DisplayPort).
The HDBaseT extender's built-in converter switch lets you connect two HDMI sources, a VGA source, and a DP source to the same remote and local HDMI display. You don't need adapters or scalers, or a video switch.
Along with manually switching your video source with easy-to-use buttons, the video extender ensures hassle-free operation with two auto-switching modes: auto-detect switching, which detects and selects a newly connected device, and priority selection, which lets you choose which port is activated by default, for automatic switching.
This HDBaseT extender features a built-in scaler that scales the image to 1080p, so you can rest assured your HDMI display will intuitively work with any source that's connected through it. Scaling is easy to do, with an intuitive OSD that's accessible using buttons on the remote receiver. Newer HDMI displays no longer support legacy resolution video signals. Without support for these common VGA resolutions, your source may not work with your new HDMI display.
The extender kit maintains your HD picture quality, even at 230 ft. (70 m) away from your video source, ensuring you can provide the best possible viewing experience.
StarTech.com Multi-Input HDBaseT Extender Kit - Built-In Switch and Video Scaler - DisplayPort HDMI and VGA Over CAT6 or CAT5e (ST121HDBTSC) - video/audio/infrared/network extender - HDMI, DisplayPort, HDBaseT, VGA - TAA Compliant
Video/audio/infrared/network extender
External
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Transmission Medium
CAT 6
Max Transfer Distance
70 m
6.1 cm x 10.6 cm x 6.7 cm
145 g
TAA Compliant
External
Wired
Max Resolution
1920 x 1200
70 m
Status Indicators
Status
1 x HDBaseT - RJ-45 , 2 x HDMI (input) - 19 pin HDMI Type A , 1 x DisplayPort (input) , 1 x VGA (input) - HD-15 female , 1 x audio - mini jack , 1 x IrDA
Remote control, IR receiver, IR transmitter, rubber feet, mounting brackets
1 x RJ-11 to RS-232 adapter , 1 x RJ-11 phone cable , 1 x network cable
RoHS, WEEE
TAA Compliant
External power adapter
18 Watt
6.1 cm
10.6 cm
6.7 cm
145 g
Shipping Weight
195 g
0 - 80% (non-condensing)
DTP4 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.63
DTP4 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.08
DTP4 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
DTP4 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.85
DTP4 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
DTP4 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.66
DTP4 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £5.05
DTP4 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £193.15
DTP4 StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £332.20
DTP4 StarTech.com Lockable Floor Stand for iPad In Stock £140.14
DTP4 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.15
Price Range Ex VAT: £500 - £750
