Connect four video sources to a remote HDMI display over CAT5/CAT6 cabling, and easily scale and switch between HDMI, DP or VGA video sources. This multi-input HDBaseT extender kit extends your A/V signals to a remote location up to 230 ft. (70 m) away. It features a built-in switch and scaler, so you can choose which video source is output from four independent video sources (2 x HDMI, 1 x VGA and 1 x DisplayPort).
The HDBaseT extender's built-in converter switch lets you connect two HDMI sources, a VGA source, and a DP source to the same remote and local HDMI display. You don't need adapters or scalers, or a video switch.
Along with manually switching your video source with easy-to-use buttons, the video extender ensures hassle-free operation with two auto-switching modes: auto-detect switching, which detects and selects a newly connected device, and priority selection, which lets you choose which port is activated by default, for automatic switching.
This HDBaseT extender features a built-in scaler that scales the image to 1080p, so you can rest assured your HDMI display will intuitively work with any source that's connected through it. Scaling is easy to do, with an intuitive OSD that's accessible using buttons on the remote receiver. Newer HDMI displays no longer support legacy resolution video signals. Without support for these common VGA resolutions, your source may not work with your new HDMI display.
The extender kit maintains your HD picture quality, even at 230 ft. (70 m) away from your video source, ensuring you can provide the best possible viewing experience.
- StarTech.com Multi-Input HDBaseT Extender Kit - Built-In Switch and Video Scaler - DisplayPort HDMI and VGA Over CAT6 or CAT5e (ST121HDBTSC) - video/audio/infrared/network extender - HDMI, DisplayPort, HDBaseT, VGA - TAA Compliant
- Video/audio/infrared/network extender
- Form Factor
- External
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- Data Link Protocol
- Transmission Medium
- CAT 6
- Max Transfer Distance
- 70 m
- 6.1 cm x 10.6 cm x 6.7 cm
- 145 g
- TAA Compliant
- 2-year warranty
- Form Factor
- External
- Localisation
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1200
- 70 m
- Status Indicators
- Status
- 1 x HDBaseT - RJ-45 , 2 x HDMI (input) - 19 pin HDMI Type A , 1 x DisplayPort (input) , 1 x VGA (input) - HD-15 female , 1 x audio - mini jack , 1 x IrDA
- Included Accessories
- Remote control, IR receiver, IR transmitter, rubber feet, mounting brackets
- Cables Included
- 1 x RJ-11 to RS-232 adapter , 1 x RJ-11 phone cable , 1 x network cable
- RoHS, WEEE
- TAA Compliant
- Power Device
- External power adapter
- 18 Watt
- 6.1 cm
- 10.6 cm
- 6.7 cm
- 145 g
- Shipping Weight
- 195 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.73 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £187.84 |
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £318.01 |
StarTech.com Lockable Floor Stand for iPad | In Stock | £137.81 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.66 |
