StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm)
Quicklinx: 93HWWS00 Mfr#: CMHOOKMW
Product Type: Cable management ring
12 In Stock
£7.01 ex VAT
£8.41 inc VAT
Add an internal or external facing cable management hook for strain relief and organization. The CMHOOKMW Multi-Directional Vertical Cable Management D-ring lets you add an internal or external facing cable hook to your server rack or cabinet, to provide an organized channel for cables.
Constructed of high-quality steel, the cable management ring measures 2.4 x 3.9in (6 x 10cm). For flexible mounting options, the cable ring features a right-angled mounting bracket with 2 sets of mounting holes, enabling you to face the D-ring in the direction that best fits your application. Providing strain relief for attached cables, multiple cable rings can be attached to your rack where you need them for a versatile cable management solution.
StarTech.com 2.4 x 3.9in Vertical Cable Management D Ring - 1.5U Metal D-Ring Hooks - Wire Organizer for 2 or 4-Post Network/Server Racks (CMHOOKMW) - cable management ring - 1U
Height (Rack Units)
1U
Product Material
Steel
10.2 cm 6.4 cm
180 g
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12V2
Product Material
Steel
Height (Rack Units)
1U
10.2 cm
6.4 cm
180 g
RoHS
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
93HW StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
93HW StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.26
93HW StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
93HW StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.50
93HW StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.59
93HW StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.65
93HW StarTech.com 19in Cable Management Panel In Stock £23.15
