StarTech.com Multi Angle Phone and Tablet Stand - 4in to 13in - Foldable
Quicklinx: DXFMWS00 Mfr#: USPTLSTND
Device Type: Tablet
Type: Stand
Device Screen Size: 13
Colour: Silver
10 In Stock
£22.35 ex VAT
£26.82 inc VAT
Work in greater comfort, with this universal phone and tablet stand. It holds your mobile device, so you don't have to. You can position your smartphone or tablet at the ideal viewing angle and browse the web, review documents or make calls, with ease.
  • Sleek and solid support
    Made of durable aluminum, the device stand provides a stable platform for multiple mobile devices, including most smartphones and 4" to 13" tablets (maximum 11 mm depth).
  • Maximize your tablet or smartphone use
    With this highly adjustable multi-device stand, you can type and swipe without having to hold your tablet or phone in your hand or set it down on your desk.
  • Change your viewing angle with ease
    Simply move the smartphone and tablet holder up or down for comfortable viewing. The multi-angle tablet stand moves smoothly, so you can adjust your viewing angle with your device still in the stand. The stand supports both landscape and portrait orientation.
  • Easy portability
    Compact and lightweight, the tablet and cellphone stand is perfect for mobile use or travel. It folds up into a flat form, so you can easily tuck it into your bag.
  • Non-slip feet
    The stand stays in place on a wide range of surfaces, with four non-slip silicone feet on the bottom surface.
StarTech.com Phone and Tablet Stand, Foldable Universal Mobile Device Holder for Smartphones & Tablets Adjustable Multi-Angle Ergonomic Cell Phone Stand for Desk Portable, 4in to 13in - Foldable Phone Holder (USPTLSTND) - desktop stand for mobile phone, tablet
Desktop stand
Intended For
Mobile phone, tablet
Screen Size Compatibility
Up to 13"
Product Material
Aluminium
7.6 cm 13 cm
Length
10.5 cm
186 g
Silver
P/N: DK30CHPH
Desktop stand
Intended For
Up to 13"
Product Material
Aluminium
7.6 cm
13 cm
Length
10.5 cm
186 g
Silver
Shipping Weight
207 g
P/N: DK30CHPH
DXFM StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.70
DXFM StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £10.03
DXFM StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £8.91
Device Type: Tablet
Type: Stand
Colour: Silver
