Work in greater comfort, with this universal phone and tablet stand. It holds your mobile device, so you don't have to. You can position your smartphone or tablet at the ideal viewing angle and browse the web, review documents or make calls, with ease.
Sleek and solid support
Made of durable aluminum, the device stand provides a stable platform for multiple mobile devices, including most smartphones and 4" to 13" tablets (maximum 11 mm depth). -
Maximize your tablet or smartphone use
With this highly adjustable multi-device stand, you can type and swipe without having to hold your tablet or phone in your hand or set it down on your desk. -
Change your viewing angle with ease
Simply move the smartphone and tablet holder up or down for comfortable viewing. The multi-angle tablet stand moves smoothly, so you can adjust your viewing angle with your device still in the stand. The stand supports both landscape and portrait orientation. -
Easy portability
Compact and lightweight, the tablet and cellphone stand is perfect for mobile use or travel. It folds up into a flat form, so you can easily tuck it into your bag. -
Non-slip feet
The stand stays in place on a wide range of surfaces, with four non-slip silicone feet on the bottom surface.
- StarTech.com Phone and Tablet Stand, Foldable Universal Mobile Device Holder for Smartphones & Tablets Adjustable Multi-Angle Ergonomic Cell Phone Stand for Desk Portable, 4in to 13in - Foldable Phone Holder (USPTLSTND) - desktop stand for mobile phone, tablet
- Product Type
- Desktop stand
- Intended For
- Mobile phone, tablet
- Screen Size Compatibility
- Up to 13"
- Product Material
- Aluminium
- 7.6 cm 13 cm
- Length
- 10.5 cm
- 186 g
- Silver
- 2-year warranty
- Designed For
- P/N: DK30CHPH
- Product Type
- Desktop stand
- Intended For
- Up to 13"
- Product Material
- Aluminium
- 7.6 cm
- 13 cm
- Length
- 10.5 cm
- 186 g
- Silver
- 2-year warranty
- Shipping Weight
- 207 g
- Designed For
- P/N: DK30CHPH
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £8.30 |
StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black | In Stock | £10.00 |
StarTech.com 1 m / 3.3 ft USB C Cable – Black | In Stock | £8.90 |
