StarTech.com MST Hub - 2-Port DisplayPort
Quicklinx: BCNBWS00 Mfr#: MSTDP122DP
12 In Stock
£41.79 ex VAT
£50.14 inc VAT
Use this multi-stream transport hub to connect two DP monitors to a single DP 1.2 port. This MST hub lets you connect two monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop. It's USB powered, so the only thing you'll need to operate the hub is your computer.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect two additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. The hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP122DP supports plug-and-play installation for a hassle-free setup.
  • Increase productivity with multiple screens
  • Connect to any display
  • Configure your displays for any environment
  • Enjoy amazing video quality, without draining system resources
    MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging. Note: When using a DisplayPort 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply. The MSTDP122DP supports plug-and-play installation for a hassle-free setup, and is backed by a StarTech.com 3-year warranty and free lifetime technical support. Average resolution bandwidth allocation 1920x1080 (High-definition 1080p) @60hz - 22% 1920x1200 @60hz - 30% 2560x1440 @60hz - 35% 2560x1600 @60hz - 38% 3840 x 2160 (Ultra HD 4K) @30hz - 38% Note: Exceeding 100% will reduce functionality.
StarTech.com 2-Port Multi Monitor Adapter, DisplayPort 1.2 MST Hub, Dual 4K 30Hz or 1080p, USB Bus Powered, Video Splitter for Extended Desktop Mode on Windows Only, DP to 2x DP MST Hub - Multi Stream Transport (MSTDP122DP) - video splitter - 2 ports
Video splitter - 2 ports
Subtype
DisplayPort
Ports
2 x DisplayPort
USB powered
5.8 cm x 38.6 cm x 1.4 cm
52 g
3-year warranty
P/N: SV231DPU34K
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
2 x DisplayPort
Max Resolution
3840 x 2160 @ 30 Hz
USB powered
2 x DisplayPort , 1 x DisplayPort
FCC, RoHS
5.8 cm
38.6 cm
1.4 cm
52 g
Limited warranty - 3 years
50 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: SV231DPU34K
BCNB StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.15
BCNB StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £21.94
BCNB StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.30
BCNB StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.22
BCNB StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.02
BCNB StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
BCNB StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.25
BCNB StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £54.31
BCNB StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £46.40
BCNB StarTech.com MST Hub - mDP to 2x DP In Stock £35.15
BCNB StarTech.com MST Hub - 4-Port DisplayPort In Stock £67.80
BCNB StarTech.com MST Hub - 2-Port DisplayPort In Stock £41.79
BCNB StarTech.com DisplayPort to 3x HDMI MST Hub In Stock £69.14
BCNB StarTech.com mDP 1.2 to HDMI MST Hub In Stock £33.29
BCNB StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £40.42
BCNB StarTech.com USB-C to DP MST Hub - 3-Port In Stock £41.68
BCNB StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.02
BCNB StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £54.16
BCNB StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
BCNB StarTech.com DP 1.4 to Dual HDMI MST Hub In Stock £31.56
