Turn an mSATA host connection into a standard SATA port. The MSAT2SAT3 mSATA to SATA adapter enables you to connect a standard SATA drive to an available mSATA port.
The adapter improves system capacity by enabling an mSATA port to host a larger SATA hard drive (tested up to 4TB). For guaranteed compatibility and performance the adapter is compliant with SATA I/II/III revisions, allowing for transfer speeds up to 6Gb per second.
Reliable connection
This adapter enables a link between mSATA drives and SATA interfaces, expanding storage options in various systems. -
Versatile compatibility
Designed to support both hard drives and solid state drives, making it a suitable option for different storage needs. -
Efficient data transfer
With a data transfer rate of 6 Gbit/s, this adapter ensures performance for demanding applications. -
Easy installation
The included mounting kit simplifies the installation process, allowing for quick setup without additional purchases. -
Resilient environmental performance
Able to operate within a temperature range of 5°C to 50°C and humidity levels of 20 to 80%, ensuring reliable functionality.
- StarTech.com mSATA to SATA HDD / SSD Adapter - Mini SATA to SATA Converter Card - mSATA to SATA 2.5/3.5 Hard Drive Adapter Converter Card (MSAT2SAT3) - storage controller - mSATA - SATA 6Gb/s
- Storage controller - internal
- Bus Type
- SATA 6Gb/s
- Interface
- mSATA
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Channel Qty
- 1
- 3 cm x 5.1 cm x 0.8 cm
- 60 g
- 2-year warranty
- Host Bus
- SATA 6Gb/s
Storage Controller
- Interface
- mSATA
- 6 Gbit/s
- Supported Devices
- Channel Qty
- 1
- 1 x - mSATA
- Connections
- 1 x SATA 6Gb/s - 7 pin Serial ATA
- Mounting Kit
- Included
- RoHS
- Limited warranty - 2 years
- 3 cm
- 5.1 cm
- 0.8 cm
- 60 g
- 5 °C
- 50 °C
- 20 - 80%
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.10 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.46 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.14 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £29.24 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.52 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £17.99 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £33.73 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £30.11 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.59 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £129.01 |
