StarTech.com MSA Compliant 10GBase-SR SFP+ Module
Quicklinx: FHKHWS00 Mfr#: SFP-10GBASE-SR-ST
Type: Modules
17 In Stock
£125.31 ex VAT
£150.37 inc VAT
The SFP-10GBASE-SR-STS is an 10 GMSA compliant fiber SFP+ transceiver that's designed, programmed and tested to work with 10GBase-LR compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 300 m (984 ft) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable connectivity
    This SFP+ transceiver module offers a secure wired connection, supporting 10 Gigabit Ethernet for high-speed data transmission.
  • Long distance capability
    Achieving a maximum transfer distance of 300 m ensures flexibility in network design and deployment, suitable for diverse environments.
  • Efficient power usage
    Operating at a power consumption of just 1.3 watts, this module promotes energy efficiency without sacrificing performance.
  • Durable construction
    With a mean time between failures (MTBF) of over 646 million hours, this module is built to withstand rigorous usage and ensure long-term reliability.
  • Advanced diagnostics
    Incorporating Digital Diagnostics Monitoring (DDM), it allows users to monitor and optimize network performance effectively.
StarTech.com MSA Uncoded Compatible SFP+ Module, 10GBASE-SR, 10GbE Multi Mode (MMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 300m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (SFP-10GBASE-SR-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
5.84 cm x 1.39 cm x 1.37 cm
20 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
646,156,559 hours
MSA
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Type: Modules
