The SFP-10GB-BX-U-STA-ST is a MSA compliant upstream fiber SFP+ transceiver which pairs with StarTech.com's SFP-10GB-BX-D-STA-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
 - StarTech.com MSA Uncoded SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Upstream BiDi Fiber Single Strand SFP+ SMF, LC 10km, Bi-Directional SFP+ Transceiver Module (Mini-GBIC), Upstream BiDi - Lifetime Warranty (SFP-10GB-BX-U-STA-ST) - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC single-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-BX-U
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1270 nm / 1330 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 10 km
 - Limited lifetime warranty
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-BX-U
 - 10GbE
 - 10 Gbps
 - 1270 nm / 1330 nm
 - 10 km
 - Digital Diagnostics Monitoring (DDM)
 - 1 x Ethernet 10GBase-BX - LC single-mode female
 - UL, FCC, MSA
 - 1.3 Watt
 - Limited warranty - lifetime
