The SFP-10GB-BX-D-STA-ST is a MSA compliant downstream fiber SFP+ transceiver which pairs with StarTech.com's SFP-10GB-BX-U-STA-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com MSA Uncoded SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand, Single Mode, SFP+, LC 10km, Mini GBIC Transceiver SFP+ Module, Downstream - Lifetime Warranty (SFP-10GB-BX-D-STA-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-BX-D
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1270 nm / 1330 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-BX-D
- 10GbE
- 10 Gbps
- 1270 nm / 1330 nm
- 10 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-BX - LC single-mode female
- UL, FCC, MSA
- 1.3 Watt
- Limited warranty - lifetime
