StarTech.com MSA Compliant 10GBase-BX SFP+ Module - Lifetime Warranty
Quicklinx: FJNKWS00 Mfr#: SFP-10GB-BX-U-STA-ST
£94.78 ex VAT
£113.73 inc VAT
The SFP-10GB-BX-U-STA-ST is a MSA compliant upstream fiber SFP+ transceiver which pairs with StarTech.com's SFP-10GB-BX-D-STA-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com MSA Uncoded SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Upstream BiDi Fiber Single Strand SFP+ SMF, LC 10km, Bi-Directional SFP+ Transceiver Module (Mini-GBIC), Upstream BiDi - Lifetime Warranty (SFP-10GB-BX-U-STA-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX-U
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10GbE
Max Transfer Distance
10 km
Plug-in module
Wired
Cabling Type
10GBase-BX-U
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 nm / 1330 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-BX - LC single-mode female
UL, FCC, MSA
1.3 Watt
Limited warranty - lifetime
