StarTech.com Mouse Pad - Cushioned/Non-Slip
Quicklinx: GPKXWS00 Mfr#: B-ERGO-MOUSE-PAD
More than 50 In Stock
£13.35 ex VAT
£16.02 inc VAT
This computer mouse pad is the ideal ergonomic accessory to keep your wrist supported as you use your mouse, reducing strain and enhancing your comfort at work. The mouse pad area is 7.0 x 6.7 inches (180 x 170 mm).
The mouse pad features a 0.78 inch (20 mm) thick integrated gel-filled wrist rest. The neutral design of the mousepad and wrist rest allows for left or right-hand use while still contouring to your wrist, alleviating discomfort and providing support.
The underside of the mouse pad and wrist rest is a non-slip surface and leaves no residue. The top surface of the mouse area is durable and easy to clean.
  • Comfort and utility
    Reduce strain and work in greater comfort with this ergonomic mouse pad while helping to support your wrist as you work. The smooth mouse area (6.7x7.1 in) enables accurate mouse tracking.
  • Carefully designed
    The gel-filled wrist rest (2.3x7.1x0.8 in) adapts to the contours of your wrist adding support and comfort for extended periods of time. The mouse pad area is durable for long-lasting use and is easy to clean.
  • Easy to keep
    The neutral shape of this computer wrist support suits left and right-handed users and the top surface of the mouse area allows for compatibility with optical and trackball mice. The black color design blends well with any workstation.
  • Non-slip
    The non-slip base keeps the computer wrist pad from slipping or shifting during use on typical desk surfaces. It won't leave stains or damage the surface in use, including glass-top desks.
StarTech.com Mouse Pad with Hand rest, 6.7x7.1x 0.8 in (17x18x2cm), Ergonomic Mouse Pad with Wrist Support, Desk Wrist Pad w/ Non-Slip PU Base for Office/Home/Computer/Laptop - Cushioned Gel Mouse Pad w/ Palm Rest - mouse pad with wrist pillow - TAA Compliant
Mouse pad with wrist pillow
Product Material
Thermoplastic polyurethane (TPU), polyurethane
23 cm x 18 cm x 2 cm
249 g
TAA Compliant
Product Material
23 cm
18 cm
2 cm
249 g
24 cm x 19 cm x 3 cm / 315 g
Non-slip base, right/left-handed, gel filled, easy-to-clean surface
TAA Compliant
Limited warranty - 2 years , Technical support - lifetime
