StarTech.com Mountable 4 Port Rugged Industrial USB Hub
Quicklinx: 6B9LWS00 Mfr#: ST4200USBM
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: DIN rail mountable
  • Hi-Speed USB
32 In Stock
£59.91 ex VAT
£71.89 inc VAT
This sturdy, industrial grade USB hub can be wall mounted or installed onto a DIN rail for convenient access to its 4 female USB ports, providing a work area, server room, or industrial area with USB 2.0 connectivity. With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 4 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
  • Reliable connectivity
    Equipped with four USB 2.0 ports, the hub allows multiple devices to be connected simultaneously, enhancing productivity.
  • Robust design
    Built for industrial environments, this hub is designed to withstand varying temperatures and conditions, ensuring durability.
  • Convenient mounting options
    The DIN rail mountable feature enables easy installation and integration into existing setups, saving workspace.
  • Power-efficient operation
    The hub supports a nominal voltage of DC 7 to 24 V, providing versatile power options for various device requirements.
  • Indicator lights for status monitoring
    Port and power status indicators provide feedback, helping to quickly identify connection and power issues.
StarTech.com Rackmount USB 2.0 Hub - 4 Port Rugged Industrial USB 2.0 Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
DC 7 - 24 V
5.7 cm x 11.5 cm x 2.6 cm
207 g
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
P/N: ITB20D3250, MSDREADU2OTG, USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
Hub - 4 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
4 x USB 2.0
Status Indicators
Port status, power
4 x USB 2.0 Type A , 1 x USB 2.0 Type B
DC 7 - 24 V
DIN-rail mounting kit
FCC, RoHS
5.7 cm
11.5 cm
2.6 cm
207 g
55 °C
6B9L StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £59.91
6B9L StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £82.96
6B9L StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
6B9L StarTech.com 4 Port Portable USB 2.0 Hub In Stock £8.39
6B9L StarTech.com 4Port USB C Hub C to A USB 2.0 In Stock £20.83
6B9L StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £142.39
6B9L StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.15
6B9L StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £109.99
6B9L StarTech.com Industrial USB 2.0 Hub In Stock £43.13
6B9L StarTech.com Industrial USB 3.0 5Gbps Hub In Stock £83.74
6B9L StarTech.com Industrial USB 3.0 Hub In Stock £290.59
6B9L StarTech.com Industrial USB 5Gbps Hub In Stock £319.96
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
