This sturdy, industrial grade USB hub can be wall mounted or installed onto a DIN rail for convenient access to its 4 female USB ports, providing a work area, server room, or industrial area with USB 2.0 connectivity. With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 4 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
- StarTech.com Rackmount USB 2.0 Hub - 4 Port Rugged Industrial USB 2.0 Hub - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 2.0
- Power
- DC 7 - 24 V
- 5.7 cm x 11.5 cm x 2.6 cm
- 207 g
- Black
- System Requirements
- Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
- 2-year warranty
- Designed For
- P/N: ITB20D3250, MSDREADU2OTG, USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
- Hub - 4 ports
- Enclosure Type
- DIN rail mountable
- Subtype
- USB
- Ports
- 4 x USB 2.0
- Status Indicators
- Port status, power
- 4 x USB 2.0 Type A , 1 x USB 2.0 Type B
- Voltage Required
- DC 7 - 24 V
- Black
- Included Accessories
- DIN-rail mounting kit
- FCC, RoHS
- OS Required
- 5.7 cm
- 11.5 cm
- 2.6 cm
- 207 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £63.76 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £83.34 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £99.39 |
StarTech.com 4 Port Portable USB 2.0 Hub | In Stock | £8.91 |
StarTech.com 4Port USB C Hub C to A USB 2.0 | In Stock | £20.83 |
StarTech.com 4-Port Industrial USB 2.0 Hub | In Stock | £143.84 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.29 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £130.03 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £135.36 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £117.58 |
StarTech.com Industrial USB 3.0 Hub | In Stock | £360.38 |
