The ST4300USBM Mountable 4-Port Industrial USB Hub (USB 3.0) offers a simple way to expand a systems current USB capability by providing 4 additional external USB 3.0 ports from a single USB 3.0 host connection, with speeds up to 5 Gbps.
Designed for extreme operating environments, this industrial-grade hub provides reliability under almost any condition and can be securely mounted to most surfaces.
Fully compliant with the SuperSpeed USB 3.0 specification, this industrial USB hub is backward compatible with USB 2.0 and 1.x specifications for simultaneous support of older USB peripherals or even older systems without USB capabilities.
Robust construction
The metal housing of the USB hub provides durability, making it suitable for both industrial and office use while reducing the risk of damage. -
High connectivity options
Equipped with four USB 3.0 ports, this hub allows quick connection for multiple devices, enhancing productivity. -
Versatile installation
This USB hub can be conveniently mounted on a wall or placed on a desk, ensuring that it fits seamlessly into various workspaces. -
Wide operating range
Designed to operate in temperatures from 0 °C to 55 °C, the hub is reliable even in demanding environments. -
Easy setup
The Plug-and-Play feature enables fast and straightforward installation, reducing downtime and simplifying device integration.
- StarTech.com 4-Port USB 3.0 Hub - Metal Industrial USB-A Hub - Wall or Desk Mountable USB Data Hub - TAA Compliant USB Expander Hub (ST4300USBM) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- Wall mountable
- USB 1.1, USB 2.0, USB 3.0
- Power
- DC 7 - 24 V
- 6 cm x 15.2 cm x 2.4 cm
- 480 g
- Black
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
- 2-year warranty
- Designed For
- P/N: ITB20D3250, MSDREADU2OTG, PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Wall mountable
- Status Indicators
- Port status, power
- 4 x USB 3.0 Type A , USB 3.0: 1 x 4 pin USB Type B
- Power Device
- External power adapter
- Voltage Required
- DC 7 - 24 V
- Black
- Plug and Play, FCC, RoHS
- OS Required
- 6 cm
- 15.2 cm
- 2.4 cm
- 480 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £58.97 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £82.96 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.08 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £105.95 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £125.14 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4-to-4 USB 3.0 Peripheral Sharing Switch | In Stock | £73.59 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £109.99 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £114.53 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £42.46 |
StarTech.com Industrial USB 3.0 Hub | In Stock | £290.59 |
StarTech.com Industrial USB 5Gbps Hub | In Stock | £314.99 |
StarTech.com Industrial USB 10Gbps Hub | In Stock | £171.41 |
