StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub
Quicklinx: 7B7PWS00 Mfr#: ST4300USBM
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
£103.00 ex VAT
£123.60 inc VAT
The ST4300USBM Mountable 4-Port Industrial USB Hub (USB 3.0) offers a simple way to expand a systems current USB capability by providing 4 additional external USB 3.0 ports from a single USB 3.0 host connection, with speeds up to 5 Gbps.
Designed for extreme operating environments, this industrial-grade hub provides reliability under almost any condition and can be securely mounted to most surfaces.
Fully compliant with the SuperSpeed USB 3.0 specification, this industrial USB hub is backward compatible with USB 2.0 and 1.x specifications for simultaneous support of older USB peripherals or even older systems without USB capabilities.
  • Robust construction
    The metal housing of the USB hub provides durability, making it suitable for both industrial and office use while reducing the risk of damage.
  • High connectivity options
    Equipped with four USB 3.0 ports, this hub allows quick connection for multiple devices, enhancing productivity.
  • Versatile installation
    This USB hub can be conveniently mounted on a wall or placed on a desk, ensuring that it fits seamlessly into various workspaces.
  • Wide operating range
    Designed to operate in temperatures from 0 °C to 55 °C, the hub is reliable even in demanding environments.
  • Easy setup
    The Plug-and-Play feature enables fast and straightforward installation, reducing downtime and simplifying device integration.
StarTech.com 4-Port USB 3.0 Hub - Metal Industrial USB-A Hub - Wall or Desk Mountable USB Data Hub - TAA Compliant USB Expander Hub (ST4300USBM) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
Wall mountable
USB 1.1, USB 2.0, USB 3.0
DC 7 - 24 V
6 cm x 15.2 cm x 2.4 cm
480 g
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
P/N: ITB20D3250, MSDREADU2OTG, PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Wall mountable
Status Indicators
Port status, power
4 x USB 3.0 Type A , USB 3.0: 1 x 4 pin USB Type B
External power adapter
DC 7 - 24 V
Plug and Play, FCC, RoHS
6 cm
15.2 cm
2.4 cm
480 g
55 °C
5 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
7B7P StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
7B7P StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £86.37
7B7P StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
7B7P StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.24
7B7P StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £131.40
7B7P StarTech.com DC Power Adapter - 12V, 5A In Stock £44.00
7B7P StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £145.20
7B7P StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £182.49
7B7P StarTech.com 4-to-4 USB 3.0 Peripheral Sharing Switch In Stock £78.92
7B7P StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
7B7P StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £115.49
7B7P StarTech.com 4 Port USB C Hub 10Gbps In Stock £120.25
7B7P StarTech.com Industrial USB 2.0 Hub In Stock £39.99
7B7P StarTech.com Industrial USB 3.0 Hub In Stock £305.13
7B7P StarTech.com Industrial USB 5Gbps Hub In Stock £322.67
7B7P StarTech.com Industrial USB 10Gbps Hub In Stock £179.97
Type: USB Hub
Speed: 5Gbps
Ports: 4
