StarTech.com Monitor Wall Mount - Aluminum
Quicklinx: CRY9WS00 Mfr#: ARMWALL
Accessory Type: Mount
£19.39 ex VAT
£23.26 inc VAT
Free up space by mounting your monitor, and adjust its position easily with this pivoting wall mount. Wall-mount your computer monitor or flat-screen TV to free up space on your desk or table. This monitor wall mount supports displays up to 27". It swivels and tilts to enable you to adjust the angle of your screen and provide viewing flexibility.
The monitor wall mount helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. (15kg) in weight. It's ideal for many different applications, including business meeting rooms, healthcare or financial settings. The monitor wall mount works well in office settings or workspaces that back against a wall.
The monitor wall mount makes it easy to change your screen position, so you can work more comfortably. It swivels +45° / - 45°, enabling you to move your screen easily to the left or right. It also tilts freely +45° / - 45°, which makes it easy to adjust the angle of your display up or down.
The aluminum monitor wall mount features slide-in wall plate construction for easy installation. To help keep your work area free of clutter, the monitor arm also features a cable clip that keep your cables neatly out of sight.
  • Save space by wall-mounting your flat-panel display
    The monitor wall mount helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. in weight. It's ideal for many different applications, including business meeting rooms, healthcare or financial settings. The monitor wall mount works well in office settings or workspaces that back against a wall.
  • Adjust your screen position with ease
  • Easy installation
StarTech.com Monitor Wall Mount - Fixed - Supports Monitors 13" to 34" - VESA Monitor Wall Mount Bracket - Aluminum - Black & Silver (ARMWALL) mounting kit - for monitor / flat panel
Mounting kit - wall-mountable
Mounting Components
Display mount, wrench
11.4 cm x 11.4 cm x 55 cm
Tilt
-45° to 45°
Pan
-45° to 45°
Adjustments
Tilt, swivel
272 g
Recommended Use
Monitor / flat panel
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 50 x 50 mm
Max Load Weight
15 kg
Material
Aluminium
Package Content
4 x M5x14 screws, 4 x washers, hex key, 4 x M4x14 screws, 2 x screws, 2 x wall screws
5-year warranty
11.4 cm
11.4 cm
55 cm
272 g
Material
Aluminium
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
13"-34"
Tilt
-45° to 45°
Pan
-45° to 45°
Adjustments
Tilt, swivel
Max Load Weight
15 kg
Limited warranty - 5 years
CRY9 StarTech.com Monitor Wall Mount - Aluminum In Stock £19.39
CRY9 StarTech.com Wall Mount Arm - Single Swivel In Stock £25.84
CRY9 StarTech.com Wall Mount Arm - Dual Swivel In Stock £34.54
CRY9 StarTech.com Thin Client Mount - VESA In Stock £26.25
CRY9 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.65
CRY9 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.93
CRY9 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.94
CRY9 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £8.76
