Free up space by mounting your monitor, and adjust its position easily with this pivoting wall mount. Wall-mount your computer monitor or flat-screen TV to free up space on your desk or table. This monitor wall mount supports displays up to 27". It swivels and tilts to enable you to adjust the angle of your screen and provide viewing flexibility.
The monitor wall mount helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. (15kg) in weight. It's ideal for many different applications, including business meeting rooms, healthcare or financial settings. The monitor wall mount works well in office settings or workspaces that back against a wall.
The monitor wall mount makes it easy to change your screen position, so you can work more comfortably. It swivels +45° / - 45°, enabling you to move your screen easily to the left or right. It also tilts freely +45° / - 45°, which makes it easy to adjust the angle of your display up or down.
The aluminum monitor wall mount features slide-in wall plate construction for easy installation. To help keep your work area free of clutter, the monitor arm also features a cable clip that keep your cables neatly out of sight.
Save space by wall-mounting your flat-panel display
The monitor wall mount helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. in weight. It's ideal for many different applications, including business meeting rooms, healthcare or financial settings. The monitor wall mount works well in office settings or workspaces that back against a wall. -
Adjust your screen position with ease
The monitor wall mount makes it easy to change your screen position, so you can work more comfortably. It swivels +45° / - 45°, enabling you to move your screen easily to the left or right. It also tilts freely +45° / - 45°, which makes it easy to adjust the angle of your display up or down. -
Easy installation
- StarTech.com Monitor Wall Mount - Fixed - Supports Monitors 13" to 34" - VESA Monitor Wall Mount Bracket - Aluminum - Black & Silver (ARMWALL) mounting kit - for monitor / flat panel
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Display mount, wrench
- 11.4 cm x 11.4 cm x 55 cm
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Adjustments
- Tilt, swivel
- 272 g
- Recommended Use
- Monitor / flat panel
- Recommended Display Size
- 13"-34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 50 x 50 mm
- Max Load Weight
- 15 kg
- Material
- Aluminium
- Package Content
- 4 x M5x14 screws, 4 x washers, hex key, 4 x M4x14 screws, 2 x screws, 2 x wall screws
- 5-year warranty
- 11.4 cm
- 11.4 cm
- 55 cm
- 272 g
- Material
- Aluminium
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 13"-34"
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Adjustments
- Tilt, swivel
- Max Load Weight
- 15 kg
- Limited warranty - 5 years
StarTech.com Monitor Wall Mount - Aluminum | In Stock | £16.45 |
StarTech.com Wall Mount Arm - Single Swivel | In Stock | £21.61 |
StarTech.com Wall Mount Arm - Dual Swivel | In Stock | £30.51 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.48 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £50.12 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
