Free up desk space and work in greater comfort with this adjustable monitor stand. Raise your monitor to eye level for more comfortable viewing, while saving desktop space. You can set this sturdy height-adjustable monitor stand on your desk or table, to support a monitor up to 32" in size and up to 22 lb. (10 kg) in weight. It features stackable columns that sit neatly on your desk or table, leaving enough space under your monitor to fit a small laptop. It even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features modular columns, made of stackable components that snap together easily to raise or lower the height of the monitor stand. You can reconfigure the columns any time to adjust the height of the stand.
The monitor stand makes it easy to work free from clutter. In the area under the stand, between the columns, there is plenty of space to place a small laptop. A convenient drawer gives you a convenient place to keep pens and other small office supplies. There is even a front slot that will hold most tablets and phones, so your important devices are close at hand when you need them.
The monitor stand is easy to assemble, so you'll be up and running in no time. The non-skid base on the columns protects your work surface from scratches or scuffs, and ensures your monitor rests securely while you work. A built-in cable manager routes cables neatly to keep them out of view.
Versatile design
This stand supports a variety of monitor sizes from 13 inches to 32 inches, making it adaptable for different setups. -
Integrated storage
The built-in drawer provides convenient space for keeping office supplies or personal items organized and within reach. -
Adjustable height
The height adjustment feature allows users to change the display height to their preferred level, enhancing ergonomic comfort. -
Sturdy support
Crafted from durable plastic, this monitor riser can handle weight up to 10 kg, ensuring stability for a variety of monitors. -
Easy assembly
Designed for quick and straightforward assembly, the monitor riser can be set up in no time, providing immediate benefit.
- Startech Adjustable Monitor Riser - Drawer - Monitors up to 32"- Adjustable Height - Monitor Stand - Computer Monitor Riser (MONSTADJD) stand - for Monitor - black
- Product Type
- Stand
- Mounting Components
- Stand surface, 8 small risers, 4 large risers
- 33 cm x 43.5 cm x 16.8 cm
- Adjustments
- 1.6 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 13"-32"
- Max Load Weight
- 10 kg
- Material
- Plastic
- Black
- 5-year warranty
- 33 cm
- 43.5 cm
- 16.8 cm
- 1.6 kg
- Material
- Plastic
- Black
AV Furniture
- Stand
- Recommended Use
- Monitor
- 13"-32"
- Adjustments
- Max Load Weight
- 10 kg
- Assembly Required
- Details
- Integrated drawer
- Limited warranty - 5 years
StarTech.com Sit-to-Stand Workstation | In Stock | £121.36 |
StarTech.com Monitor Riser with Drawer | In Stock | £24.85 |
StarTech.com Monitor Riser - Large (19.7") | In Stock | £24.53 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Under Desk Keyboard Tray | In Stock | £55.81 |
StarTech.com Monitor Riser Stand | In Stock | £41.78 |
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £32.40 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £33.45 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com Ergonomic Monitor Riser Stand | In Stock | £33.19 |
