Create a more ergonomic workspace. This strong and sturdy monitor riser stand lifts your display off of your desk for more comfortable viewing, helping to prevent neck strain. Its attractive silver and black design adds to the aesthetic appeal of your workspace, and creates storage space underneath.
Elevate your display to position your monitor. You can customize the height of the computer monitor riser, adjusting easily to three different heights: 4.9", 5.9" or 6.9" (12.5, 15 or 17.5 cm) off the desk surface.
With a robust 10.5" x 16" steel surface area and an aluminum base, the monitor riser provides a stable platform for a monitor up to 32" with maximum weight capacity of up to 22 lb. (10 kg). You can also use it for your laptop. The non-skid bottom surface of the feet provides a solid grip while protecting your desk surface from scratches and scuff-marks. It's ideal for a variety of desk surfaces including glass-top desks.
Maximize your work space and create a clutter-free area. Store your mouse, phone, and other items underneath the monitor shelf so they are out of view, but not out of reach. You can also use the riser stand to raise your printer, freeing up desk or counter space underneath. The integrated cable management slots keep cables organized and out of view.
With fast and easy setup, you'll be ready to work with the monitor riser within minutes.
Sturdy construction
Made from a combination of aluminum and steel, this monitor riser stand provides a strong and durable platform for your display. -
Height adjustable
The stand can be easily adjusted to different heights, allowing users to find the most comfortable viewing angle. -
Suitable for large displays
Recommended for monitors up to 32 inches, making it a versatile option for various desktop setups. -
Organized workspace
By elevating the monitor, the stand also helps in creating a more organized workspace, freeing up valuable desk space. -
Easy to assemble
The monitor riser stand requires minimal assembly, making it a quick and convenient addition to any office setup.
- StarTech.com Monitor Riser Stand - For up to 32" Monitor - Height Adjustable - Computer Monitor Riser - Steel and Aluminum (MONSTND) stand - for Monitor
- Product Type
- Stand - desktop
- 40.5 cm x 30.5 cm x 12.5 cm
- Adjustments
- 3.2 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 32"
- Max Load Weight
- 10 kg
- Material
- Aluminium, steel
- 5-year warranty
- 40.5 cm
- 30.5 cm
- 12.5 cm
- 3.2 kg
- Material
- Aluminium, steel
AV Furniture
- Stand
- Recommended Use
- Monitor
- Placing / Mounting
- Desktop
- 32"
- Adjustments
- Max Load Weight
- 10 kg
- Assembly Required
- Limited warranty - 5 years
StarTech.com Monitor Riser with Drawer | In Stock | £24.85 |
StarTech.com Monitor Riser - Large (19.7") | In Stock | £24.53 |
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £31.89 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £32.93 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £53.69 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £60.16 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com Ergonomic Monitor Riser Stand | In Stock | £33.19 |
