Maximize your desktop space and elevate your screen for more comfortable viewing with this monitor riser. It clamps on easily to your desk to open up more surface space, giving you an extra wide monitor shelf with a minimal footprint. The attractive black finish complements your office decor.
Enjoy an organized, clutter-free workspace with this space-saving monitor stand, 25.6" x 10.2" (65 cm x 26 cm). The extra wide monitor shelf provides ample room to hold your monitor and desk accessories. Use the large area underneath to store a full-size keyboard and other items, to keep everything within easy reach.
With its heavy-duty base and sturdy platform, the clamp-on monitor shelf provides stable support for a single monitor up to 34", with a maximum weight capacity up to 44 lb. (20 kg). You can also use the monitor stand to raise your laptop or printer, freeing up desk or counter space underneath. The integrated cable management slots keep cables organized and out of view.
The office desk monitor shelf offers fast and easy set up, with a C-clamp that attaches easily on to desk surfaces up to 1.3" (33 mm) in thickness. It offers a great space-saving solution without permanently altering your desk or table surface.
- StarTech.com Monitor Riser Stand - Clamp-on Monitor Shelf for Desk - Extra Wide 25.6" (65 cm) For up to 34" Monitors - Black (MNRISERCLMP) mounting kit - for Monitor - black
- Product Type
- Mounting kit - desk-mountable
- 65 cm x 26 cm x 13 cm
- 4 kg
- Recommended Use
- Monitor
- Recommended Display Size
- Up to 32"
- Max Load Weight
- 20 kg
- Black
- Package Content
- 4 x washers, hex key, desk clamp, 4 x screws
- 5-year warranty
- 65 cm
- 26 cm
- 13 cm
- 4 kg
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- Up to 32"
- Max Load Weight
- 20 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 4.25 kg
- Limited warranty - 5 years
StarTech.com Portable Laptop Stand | In Stock | £16.91 |
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £32.40 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £33.45 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com Laptop Stand - 2-in-1 Riser/Vertical Stand | In Stock | £24.47 |
StarTech.com Laptop Stand for Desk | In Stock | £65.56 |
StarTech.com Ergonomic Monitor Riser Stand | In Stock | £33.19 |
StarTech.com Telescopic Laptop Stand/Riser | In Stock | £69.98 |
StarTech.com Rotating Laptop Stand/Riser | In Stock | £51.40 |
