The StarTech.com Monitor Desk Mount is a comprehensive solution designed to enhance your viewing experience and workspace organization. Capable of supporting LCD displays up to 30 inches or 76.2 cm, this mounting kit is perfect for a wide variety of screens. Its adjustable arm offers extensive flexibility, including extension, pivot, rotation, swivel, and tilt adjustments, allowing you to find the perfect screen angle and height for both productivity and comfort.
Constructed from high-quality materials such as aluminum, steel, and plastic, the mount is not only durable but also provides a stable base for your display. The integrated cable management channel ensures that your workspace remains clutter-free by neatly organizing and hiding cables. Additionally, the desk-mountable design frees up valuable desk space, making it an ideal choice for any office or home setup.
Assembly is made simple with the inclusion of all necessary mounting components and a detailed instruction manual, ensuring a quick and hassle-free setup. Whether you're looking to improve your ergonomic posture or simply enhance your desk's aesthetics, the StarTech.com Monitor Desk Mount offers a reliable and versatile solution.
Versatile adjustments
With a range of adjustments including extension, pivot, rotation from -90° to 90°, swivel from -120° to 120°, and tilt from -15° to 90°, this monitor desk mount offers flexibility to position your screen for optimal viewing and productivity. -
Robust build quality
Constructed from a combination of aluminum, plastic, and steel, the mount is designed for durability and stability, ensuring your display is securely held in place. The inclusion of a cable management channel further enhances the setup by keeping cables organized and out of sight. -
Easy installation
Assembly is straightforward with all necessary components included in the package, such as monitor thumbscrews, VESA monitor mount, base cushion, cable management clip, hex key, pole mount assembly, spring arm, and swivel arm. This ensures a hassle-free setup process, allowing you to enjoy a cleaner, more organized workspace in no time.
- StarTech.com Monitor Desk Mount, VESA 75x75/100x100, 27/30-inch Screens mounting kit - adjustable arm - for LCD display - black - TAA Compliant
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- Mounting Components
- Articulating arm
- 67.4 cm x 10.3 cm
- Adjustable Height
- 27-30.2 cm
- Tilt
- -15° to 90°
- Rotation
- -90° to 90°
- Swivel
- -120° to 120°
- Adjustments
- Pivot, extension
- 3.6 kg
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9 kg
- Material
- Aluminium, steel, plastic
- Black
- TAA Compliant
- Package Content
- Spring arm, pole mount assembly, swivel arm, cable management clip, hex key, VESA monitor mount, 4 x monitor thumbscrews, base cushion
- 10 years warranty
- 67.4 cm
- 10.3 cm
- Adjustable Height
- 27-30.2 cm
- 3.6 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Articulating arm
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Desk-mountable
- Cable Management
- Cable management channel
- Up to 30"
- Tilt
- -15° to 90°
- Rotation
- -90° to 90°
- Swivel
- -120° to 120°
- Adjustments
- Pivot, extension
- Max Load Weight
- 9 kg
- TAA Compliant
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 29 cm x 47 cm x 13.5 cm / 4.6 kg
- Limited warranty - 10 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £79.81 |
StarTech.com 27" Monitor Privacy Screen | In Stock | £101.53 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £73.04 |
