Create an ergonomic work area and save space by mounting your monitor above your desk, and re-position easily. Save valuable desk space and position your monitor in a more comfortable viewing position. Constructed of high-grade steel, this monitor desk mount for up to 32" monitors makes it easy to suspend your display above your desk or other work surface.
Clear up your desk surface while creating an ergonomic workspace. This simple yet rugged monitor mount supports displays 13" to 32" (330 to 813 mm) in size and 17.6 lb. (8 kg) in weight. Easily rotate, tilt and swivel, to adjust your screen position and find the perfect viewing angle. You can also adjust the height of your monitor along the vertical pole to a maximum height of 17.4" (443 mm) to your desired position, to reduce neck and eye strain.
The heavy-duty steel mount is built for long-lasting performance. The surface finish features a powder coating to help resist scratches.
The monitor desk mount makes it easy to mount a VESA mount compatible display above your desk, table or other surface, using the included C-clamp or grommet mount. A detachable VESA panel enables simple attachment of your monitor, then you just slide your monitor onto the mount. To help keep your work area free of clutter, the monitor mount also features cable clips that keep your cables neatly out of sight.
Sturdy construction
Composed of durable plastic and steel, this desk mount ensures stability and strength for secure monitor support. -
Versatile mounting options
Choose between C-clamp or grommet installation to adapt to various desk configurations and preferences. -
Full adjustability
Easily modify the height, tilt from -45° to 45°, and pan 180°, along with a 360° rotation for the best viewing experience. -
Organized cabling
Includes a cable management clip to keep wires neatly arranged, promoting a clean and efficient workspace. -
Comprehensive package content
Comes complete with all necessary screws, spacers, and hex keys, making installation straightforward and hassle-free.
- StarTech.com Single Monitor Desk Mount, Single Screen Heavy Duty Pole Mount for up to 8kg VESA Compatible Displays, Ergonomic Height Adjustable Monitor Arm Mount, Desk Clamp/Grommet - Small Footprint Design (ARMPIVOTV2) mounting kit - for Monitor - black
- Product Type
- Mounting kit - C-clamp, grommet, desk-mountable
- Mounting Components
- Desk clamp mount, pole clamp, pole, grommet plate, washers, cable management clip
- 11.4 cm x 54.8 cm x 14.8 cm
- Tilt
- -45° to 45°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- Height, swivel
- Recommended Use
- Monitor
- Recommended Display Size
- 13"-32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Plastic, steel
- Black
- Package Content
- 4 x M4x12 screws, hex key (4mm), 4 x M5x12 screws, spacers, 5 x rubber pads, grommet collar, hex key (6mm), thumbscrew, 4 x M4x16 screws, 3 x pole screws
- 5-year warranty
- 11.4 cm
- 54.8 cm
- 14.8 cm
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Monitor
- Placing / Mounting
- 13"-32"
- Tilt
- -45° to 45°
- Pan
- 180°
- Rotation
- 360°
- Adjustments
- Height, swivel
- Max Load Weight
- 8 kg
- Limited warranty - 5 years
StarTech.com Sit-to-Stand Workstation | In Stock | £243.11 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £69.47 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.19 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.93 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.28 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.60 |
