Increase your desk space and add versatility and ergonomics to your work/home setup with this VESA-compatible laptop and monitor desk mount. The laptop tray (11.8x11in / 300x280mm) is large enough to hold a laptop between 9.4-16.5in (240-420mm) wide, 1in (25.4mm) thick, and up to 10lbs (4.5kg). The monitor arm allows you to mount a VESA compatible (75x75mm or 100x100mm) display up to 32in with a maximum weight of 17.6lbs (8kg).
Versatile compatibility and solid construction
This well-ventilated laptop tray includes rubber pads to prevent scuffs and scratches. In addition, the tray features two independent adjustable padded arms that serve as a cradle to secure the laptop and can be independently positioned and secured along the sides of the tray to prevent blocking any port configuration on a laptop. The tray and monitor mount are both solid steel. -
Wide range of motion
The VESA mounts offer wide adjustability options such as tilt +/-45° swivel +/-90°; and rotation 360°. The height can be adjusted along the 17.4in / 443mm pole and the arms can also extend out a maximum of 15.7in / 399mm out. Two joints (at the pole and middle of the arms) allow them to swivel +/-180°. -
Ergonomic design
The multiple adjustment options allow the laptop to be positioned at eye level improving your posture and comfort, and when positioning the monitor mount beside it, enhances your screen real estate and productivity. -
Mounting options
Using the interchangeable desk clamp (C-clamp) you can easily attach and secure the mount to a desk or grommet hole by hand (grommet hole 0.39-2.36in / 10-60mm and desks 0.39-3.46in / 10-88mm thick). You can remove the laptop tray or monitor with no tools for hassle-free changes in your setup. To keep everything neatly arranged, cable management clips around the support arms keep the cables organized and out of the way. A2-LAPTOP-DESK-MOUNT is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
 - StarTech.com Monitor Arm with VESA Laptop Tray, For a Laptop (4.5kg / 9.9lb) and a Single Display up to 32" (8kg / 17.6lb), Black, Adjustable Desk Laptop Arm Mount, C-clamp/Grommet Mount - VESA Monitor Mount (A2-LAPTOP-DESK-MOUNT) mounting kit - for monitor / notebook - black
- Product Type
 - Mounting kit - desktop
- Mounting Components
 - Pole, notebook tray, monitor arm, notebook tray arm
- Integrated Devices
 - Ventilation system
 - 28 cm x 87.6 cm x 54.8 cm
- Tilt
 - -45° to 45°
- Rotation
 - 360°
- Swivel
 - -90° to 90°
- Adjustments
 - Height, tilt, swivel, rotation
 - 6.3 kg
- Recommended Use
 - Monitor / notebook
- Recommended Display Size
 - 13"-34"
- VESA Mounting Interface
 - 100 x 100 mm, 75 x 75 mm
- Max Load Weight
 - 8 kg
- Material
 - Plastic, steel
 - Black
- Package Content
 - 2 x swivel arm, cable-management clip (pole), pole cap, 2 x VESA monitor mounts, 8 x M4x12 screws, hex key (4mm), 5 x rubber pads, desk clamp, 8 x washers, hex key (6mm), 8 x M5x12 screws, 8 x M4x16 screws, 8 x M5x16 screws, grommet base plate, 1 x grommet clamp plate, 4 x laptop tray mounting screws, 2 x VESA mount knobs, 3 x pole mounting screws
 - 5-year warranty
 - 28 cm
 - 87.6 cm
 - 54.8 cm
 - 6.3 kg
- Material
 - Plastic, steel
 - Black
- Package Content
AV Furniture
 - Mounting kit
- Recommended Use
- Placing / Mounting
 - Desktop
- Cable Management
 - Integrated cable management
 - 13"-34"
- Tilt
 - -45° to 45°
- Rotation
 - 360°
- Swivel
 - -90° to 90°
- Adjustments
- Max Load Weight
 - 8 kg
Dimensions & Weight Details
- Dimensions
 - Tray - width: 30 cm height: 28 cm
- Shipping Dimensions (WxDxH) / Weight
 - 44.8 cm x 30.5 cm x 13 cm / 6.3 kg
 - Limited warranty - 5 years
