StarTech.com Monitor Arm - VESA Mount
Quicklinx: H138WS00 Mfr#: A2-LAPTOP-DESK-MOUNT
Accessory Type: Mount
34 In Stock
£23.87 ex VAT
£28.64 inc VAT
Increase your desk space and add versatility and ergonomics to your work/home setup with this VESA-compatible laptop and monitor desk mount. The laptop tray (11.8x11in / 300x280mm) is large enough to hold a laptop between 9.4-16.5in (240-420mm) wide, 1in (25.4mm) thick, and up to 10lbs (4.5kg). The monitor arm allows you to mount a VESA compatible (75x75mm or 100x100mm) display up to 32in with a maximum weight of 17.6lbs (8kg).
  • Versatile compatibility and solid construction
    This well-ventilated laptop tray includes rubber pads to prevent scuffs and scratches. In addition, the tray features two independent adjustable padded arms that serve as a cradle to secure the laptop and can be independently positioned and secured along the sides of the tray to prevent blocking any port configuration on a laptop. The tray and monitor mount are both solid steel.
  • Wide range of motion
    The VESA mounts offer wide adjustability options such as tilt +/-45° swivel +/-90°; and rotation 360°. The height can be adjusted along the 17.4in / 443mm pole and the arms can also extend out a maximum of 15.7in / 399mm out. Two joints (at the pole and middle of the arms) allow them to swivel +/-180°.
  • Ergonomic design
    The multiple adjustment options allow the laptop to be positioned at eye level improving your posture and comfort, and when positioning the monitor mount beside it, enhances your screen real estate and productivity.
  • Mounting options
    Using the interchangeable desk clamp (C-clamp) you can easily attach and secure the mount to a desk or grommet hole by hand (grommet hole 0.39-2.36in / 10-60mm and desks 0.39-3.46in / 10-88mm thick). You can remove the laptop tray or monitor with no tools for hassle-free changes in your setup. To keep everything neatly arranged, cable management clips around the support arms keep the cables organized and out of the way. A2-LAPTOP-DESK-MOUNT is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Monitor Arm with VESA Laptop Tray, For a Laptop (4.5kg / 9.9lb) and a Single Display up to 32" (8kg / 17.6lb), Black, Adjustable Desk Laptop Arm Mount, C-clamp/Grommet Mount - VESA Monitor Mount (A2-LAPTOP-DESK-MOUNT) mounting kit - for monitor / notebook - black
Mounting kit - desktop
Mounting Components
Pole, notebook tray, monitor arm, notebook tray arm
Integrated Devices
Ventilation system
28 cm x 87.6 cm x 54.8 cm
Tilt
-45° to 45°
Rotation
360°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
6.3 kg
Recommended Use
Monitor / notebook
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, steel
Package Content
2 x swivel arm, cable-management clip (pole), pole cap, 2 x VESA monitor mounts, 8 x M4x12 screws, hex key (4mm), 5 x rubber pads, desk clamp, 8 x washers, hex key (6mm), 8 x M5x12 screws, 8 x M4x16 screws, 8 x M5x16 screws, grommet base plate, 1 x grommet clamp plate, 4 x laptop tray mounting screws, 2 x VESA mount knobs, 3 x pole mounting screws
5-year warranty
28 cm
87.6 cm
54.8 cm
6.3 kg
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor / notebook
Placing / Mounting
Desktop
Integrated Devices
Ventilation system
Cable Management
Integrated cable management
13"-34"
Tilt
-45° to 45°
Rotation
360°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
Dimensions
Tray - width: 30 cm height: 28 cm
44.8 cm x 30.5 cm x 13 cm / 6.3 kg
Limited warranty - 5 years
H138 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
H138 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
H138 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
