StarTech.com Monitor and Laptop Arm
Quicklinx: C9W4WS00 Mfr#: ARMUNONB
Accessory Type: Stand
£113.62 ex VAT
£136.34 inc VAT
Raise your laptop and monitor off your desk, to create a dual-display workspace and increase productivity. This monitor arm lets you create a convenient and cost-effective dual-monitor workspace, using your laptop as your secondary display. It features an integrated stand that elevates your laptop off of your desk, seamlessly aligning it with your other display.
Integrate your laptop display to provide enhanced productivity. The tray lets you adjust the height of your laptop, so that it's in line with your monitor, giving you the same functionality as a dual-monitor setup without having to purchase a second monitor.
With two displays you have the extra screen space that you need to simplify multitasking and maximize productivity. Using two displays makes it easier to reference material on one monitor while working on the other, saving you the time and hassle of having to flip back and forth between documents. Plus, for viewing longer pages or blocks of code without having to scroll down your screen, the LCD arm also supports simple landscape-to-portrait display rotation.
The flexible monitor arm and stand let you extend, tilt, and swivel the monitor and the laptop with a full range of motion across multiple axes, with spring-assisted height adjustments for effortless positioning. It makes it easy to create an ergonomic work environment that's tailored to your specific needs.
The versatile arm lets you elevate your laptop and traditional monitor stand off of your desk. This gives you more surface area for additional hardware or for completing physical tasks such as drafting or reading paper documents.
The monitor arm is perfect for smaller work environments, like cubicles, providing everything you need while using less space.
Also, by combining the arm with a monitor, laptop, docking station, keyboard and mouse, you can comfortably set yourself up at a hot desk in the office, and easily recreate the same setup at home. It's perfect for business travelers and users who are constantly on the go.
The monitor arm supports a display of 15 to 27" up to a maximum weight capacity of 17.6 lb. (8 kg) and features cable management clips to help keep things neat. The integrated laptop stand also supports a weight capacity of 17.6 lb. (8 kg) and offers its own integrated cable management clips.
  • Versatile design
    Designed for LCD displays and notebooks, this mounting kit adapts easily to various devices, enhancing usability across different setups.
  • Robust construction
    Made from aluminum, this monitor stand offers durability and stability, ensuring reliable performance for everyday use.
  • 360° rotation capability
    Enjoy flexible viewing options with the ability to rotate your display fully, allowing for side-to-side adjustments as needed.
  • Easy cable management
    Keep the workspace uncluttered with integrated cable management that helps organize and route wires effectively.
  • Adjustable height and angle
    Features multiple adjustment options including height, pan, and tilt, allowing for personalized ergonomics and comfort while working.
StarTech.com Laptop Monitor Stand - Computer Monitor Stand - Full Motion Articulating - VESA Mount Monitor Desk Mount mounting kit - adjustable arm - for LCD display / notebook - black
Mounting kit (adjustable arm) - desk-mountable
Mounting Components
Pole clamp, rubber pad, laptop shelf, spring arm, swivel arm, 4 spacers, cable management clip, screws, key
Rotation
360°
Adjustments
Height, pan, tilt
5 kg
Recommended Use
Recommended Display Size
15"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium
Package Content
M5 allen key
5 kg
Material
Aluminium
Package Content
M5 allen key
AV Furniture
Mounting kit
Mounting Components
Design
Adjustable arm
Recommended Use
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
15"-27"
Rotation
360°
Adjustments
Height, pan, tilt
Max Load Weight
8 kg
Dimensions & Weight Details
Dimensions
Shelf - width: 32 cm height: 24 cm
C9W4 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.25
C9W4 StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £67.93
C9W4 StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit In Stock £90.08
C9W4 StarTech.com Articulating Monitor Arm In Stock £124.94
C9W4 StarTech.com Sit-to-Stand Workstation In Stock £124.33
C9W4 StarTech.com USB-C Multifunction Adapter In Stock £47.42
C9W4 StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £71.69
C9W4 StarTech.com Thin Client Mount - VESA In Stock £23.04
C9W4 StarTech.com Under Desk Keyboard Tray In Stock £55.82
C9W4 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
C9W4 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
C9W4 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £78.75
C9W4 StarTech.com Desk Mount Laptop Arm or 34" Monitor VESA Mount In Stock £92.48
C9W4 StarTech.com Desk Mount Monitor Arm In Stock £63.55
C9W4 StarTech.com Single Monitor Stand In Stock £54.73
