StarTech.com Mobile Workstation Cart
Quicklinx: GJX2WS00 Mfr#: WKSTNCART
Accessory Type: Trolley
Hurry, only 3 left in stock!
£396.60 ex VAT
£475.92 inc VAT
Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart (WKSTNCART).
  • Effortless Height Adjustment
    The movable standing desk includes a single monitor mount that supports a VESA compatible (75x75mm/100x100mm) display up to 17.6lb (8kg), and can be adjusted (and locked) in 1.6" (4 cm) increments to any height between 50.4" (128 cm) and 63" (160 cm) from the floor using the easy-grip handle. The monitor also has a +/-30 degree tilt so each user can find their desired angle they need to work most comfortably.
  • Built-In CPU Mount
    The CPU holder has an adjustable width ranging from 4.8" to 8.3" (12.2cm to 21.2cm) and can easily be adjusted by hand, without the use of tools. The mount accommodates most computer towers up to 22lb (10kg), and features two safety straps to ensure it's secured, especially when moving from one location to another.
  • Perfect for Any Environment
    Providing users with a complete workstation solution, the portable desk cart can be used in a variety of settings, including office training rooms, warehouses and manufacturing sites, medical institutions, schools and IT departments. WKSTNCART is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart cart - for LCD display / keyboard / mouse / CPU - black
Cart
85 cm x 64.5 cm x 140 cm
Adjustable Height
1.3-1.6 cm
Tilt
-30° to 30°
Rotation
-180° to 180°
Adjustments
Height, tilt
18 kg
Recommended Use
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Steel
Wheels Qty
4
Package Content
4 x M4x12 screws, 4 x M5x12 screws, hex key (5mm), CPU strap, column, hex key (6mm), 4 x M4x16 screws, 4 x spacers, caster wrench, M6 wrench, mouse pad, 4 x M5x16 screws, keyboard tray, CPU holder, base, 6 x M8x30 screws, 2 x M6 nuts, 4 x washers (large), 4 x casters, 4 x washers (small), column cap, 6 x M6x6 screws
85 cm
64.5 cm
140 cm
Adjustable Height
1.3-1.6 cm
18 kg
Material
Steel
Package Content
AV Furniture
Cart
Recommended Use
Shelf Qty
1
Cable Management
Integrated cable management
Tilt
-30° to 30°
Rotation
-180° to 180°
Adjustments
Height, tilt
Max Load Weight
8 kg
Wheels Qty
4
Dimensions & Weight Details
110 cm x 72.5 cm x 17.7 cm / 20.1 kg
