Mobile TV Cart - Multimedia Device Shelf - For 60" to 100" Displays
This Mobile TV Stand enables you to create a mobile media center, making it easier to move your AV equipment across classrooms, offices, or learning environments. For better stability and safety, the mobile cart was engineered with a large 1.22m x 0.71m base that will let you can mount large displays of 60" to 100" and up to 220lb in weight.
Fully Adaptable to your setup
This mobile tv stand with mount will adapt to the different setups that you may encounter in your office space. You can adjust the height of your display from 1.2m to 1.68m from the center of the TV to the floor; and the included adjustment indicators allow you to perform precise adjustments for the ideal viewing height. Additionally, the height adjustment indicators make installation easier and enable you to note the preferred height for specific environments. You can also tilt the viewing angle within +5/-10° to best suit your environments and reduce glare.
Storage for your AV devices
For increased portability and customization, this universal mobile cart offers two independently adjustable device shelves (webcam shelf and equipment shelf) that each support up to 11lb/5kg. The webcam shelf can be raised up to 2.37m, while the equipment shelf can be raised up to 0.90m from the floor.
Durable construction
The heavy-duty TV stand's durable construction makes it ideal for commercial use, in environments with multiple users and frequent movement between areas. Built-in cable management keeps your cables organized and hidden from view.
STNDMTV100 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
This mobile tv stand with mount will adapt to the different setups that you may encounter in your office space. You can adjust the height of your display from 1.2m to 1.68m from the center of the TV to the floor; and the included adjustment indicators allow you to perform precise adjustments for the ideal viewing height. Additionally, the height adjustment indicators make installation easier and enable you to note the preferred height for specific environments. You can also tilt the viewing angle within +5/-10° to best suit your environments and reduce glare. -
- StarTech.com Mobile TV Stand, Heavy Duty TV Cart for 60-100" Display (100kg/220lb), Height Adjustable Rolling Flat Screen Floor Standing on Wheels, Universal Television Mount w/Shelves - W/ 2 equipment shelves cart - for flat panel - black, silver
- Product Type
- Cart
- 1.22 m x 71 cm
- Adjustable Height
- 120-170 cm
- Tilt
- -10° to 5°
- Adjustments
- Height, tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 60"-100"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 200 mm, 800 x 600 mm, 900 x 600 mm, 300 x 300 mm, 600 x 300 mm, 1000 x 600 mm, 200 x 300 mm, 200 x 400 mm
- Max Load Weight
- 100 kg
- Material
- Aluminium, steel
- Black, silver
- Wheels Qty
- 4
- Package Content
- 8 x spacers (small), hex key, wrench, universal plate, connecting plate, camera shelf, multimedia shelf, 8 x spacers (large), 2 x knobs, 4 x M6x25 screws, base, 2 handles, 4 x locking casters, left column, right column, left TV mounting bracket, right TV mounting bracket, 2 x top covers, support bar, 3 x M4x6 screws, 2 x M6x6 round-head screws, 2 x M6x25 hex screws, 6 x M6x14 screws, 8 x M8x25 hex screws, 2 x M6x25 button head screws, 4 x M5x14 round-head screws, 4 x M6x14 round-head screws, 4 x M6x30 round-head screws, 4 x M8x30 round-head screws, 4 x M8x50 round-head screws, 4 x Square Washers
- 5-year warranty
- 1.22 m
- 71 cm
- Adjustable Height
- 120-170 cm
- Material
- Aluminium, steel
- Black, silver
- Package Content
AV Furniture
- Cart
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 60"-100"
- Tilt
- -10° to 5°
- Adjustments
- Height, tilt
- Max Load Weight
- 100 kg
- Wheels Qty
- 4
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 130 cm x 81 cm x 18 cm / 39.2 kg
- Limited warranty - 5 years
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter | In Stock | £32.14 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.33 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.85 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.22 |
StarTech.com Mobile TV Cart, Portable/Rolling TV Stand 37-70" | In Stock | £286.61 |
StarTech.com Dual TV Cart - 37-60in Display | In Stock | £402.73 |
StarTech.com Rolling TV Cart/Portable Mount | In Stock | £418.75 |
