StarTech.com Mobile TV Cart, Portable/Rolling TV Stand 37-70"
Quicklinx: GBTJWS00 Mfr#: MBLTVSTNDEC
Type: Cart
11 In Stock
£286.61 ex VAT
£343.93 inc VAT
Mobile Display Mount - Multimedia Device Shelf & Storage Compartment - For 37" to 70" Displays
This Mobile TV Stand enables you to create a mobile media center with displays from 37" to 70" and up to 154lb in weight, making it easier to move your AV equipment across classrooms, offices, or learning environments. For better stability and safety, the mobile cart was engineered with a 0.92m x 0.70m base.
Fully Adaptable to your setup
This rolling tv stand with a mount will adapt to the different setups that you may encounter in your office space. You can tilt the viewing angle within 0/+5° to best suit your environments and reduce glare and rotate your display -90°/+90° for portrait or landscape orientations.
Storage for your AV devices
For increased portability, this universal mobile cart offers a device shelf for equipment that needs to be easily accessible and supports up to 11lb/5kg, and a storage compartment behind the TV ideal for storing equipment like power bars, or media players. To avoid interference with larger displays in portrait mode, the equipment shelf protrudes out from the back.
Durable construction
The heavy-duty TV stand's durable construction makes it ideal for commercial use, in environments with multiple users and frequent movement between areas. Additionally, it is equipped with 4 polyurethane casters which are lockable using a pedal and will provide smooth movement across different types of floors/carpet, while avoiding drag marks on surfaces. Built-in cable management keeps your cables organized and hidden from view; cables are run through the columns with entry points below the storage compartment.
The MBLTVSTNDEC mobile TV cart stand is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Fully Adaptable to your setup
  • Storage for your AV devices
StarTech.com Mobile TV Cart, Portable Rolling TV Stand for 37-70" VESA Display (154lb/70kg), with Shelf & Storage Compartment, Rotate/Tilt Display, Universal TV Mount on Casters/Wheels - Mobile TV Stand w/ Casters (MBLTVSTNDEC) cart - for flat panel
Cart
92 cm x 70.2 cm x 160 cm
Tilt
0° to 5°
Rotation
-90° to 90°
23.8 kg
Recommended Use
Flat panel
Recommended Display Size
37"-70"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 300 mm, 350 x 350 mm
Max Load Weight
70 kg
Material
Steel
Wheels Qty
4
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 8 x spacers (small), hex key (4mm), 4 x M8x50 screws, M6 wrench, base, 16 x M6x12 screws, 4 x locking casters, 2 x base columns, 2 x upper columns, equipment shelf, 4 x cable covers, 5 x cable clips and holders, spacer (large), front bracket cover, VESA mounting plate, 2 shelf brackets, M6x18 screw, 8 x M8x8 screws, 2 x VESA extension arms (right), 2 x VESA extension arms (left), 8 x M6x8 screws, 8 x M8x20 screws, M10 wrench, rear bracket cover, hex key (1.5mm)
92 cm
70.2 cm
160 cm
23.8 kg
Material
Steel
Package Content
AV Furniture
Cart
Recommended Use
Flat panel
Shelf Qty
1
Cable Management
Integrated cable management
37"-70"
Tilt
0° to 5°
Rotation
-90° to 90°
Max Load Weight
70 kg
Wheels Qty
4
Brakes Qty
4
Dimensions & Weight Details
Dimensions
Cart - width: 92 cm, depth: 70.2 cm, height: 160 cm , Shelf - width: 42 cm, depth: 29 cm
100 cm x 86.5 cm x 13.5 cm / 26.4 kg
GBTJ StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
GBTJ StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.22
GBTJ StarTech.com TV Accessory Mount - Universal - Media Player/Apple TV In Stock £26.75
GBTJ StarTech.com Rolling TV Cart/Portable Mount In Stock £418.75
Type: Cart
