StarTech.com Mobile Tablet Stand - 7 to 11"
Quicklinx: GJK1WS00 Mfr#: STNDTBLTMOB
Accessory Type: Stand
Hurry, only 3 left in stock!
£71.66 ex VAT
£85.99 inc VAT
Mobile Tablet Stand - For 7" to 11" Tablets - Height Adjustable - Detachable Holder
This rolling tablet floor stand is perfect for delivering presentations and rolling your tablet in environments such as healthcare, education, tradeshows etc. The stand fits tablets ranging from 7" to 11" (6.6" to 7.8" in width) and up to 0.41" (10.5mm) in thickness. Use it with your Apple iPad (including the 10.2 iPad, and 11" iPad Pro) or other compatible tablets.
Perfect for Presentations
This tablet stand on wheels enables you to use your tablet to deliver engaging presentations, while you stay focused on your audience and the content you're delivering. You can use your tablet as a visual cue or teleprompter, without having to hold it or repeatedly look down at it while you're speaking.
With lockable casters and a strong base; this mobile tablet holder offers a great balance between mobility and stability, perfect for photography, videography, and educational environments.
Adjustable Height and Viewing Angle
The ergonomic tablet stand has a height adjustability range of 36.4" to 57.8" (92.5cm to 146.8cm) from the floor so you can adjust it to your ideal height; whether you are sitting or standing.
With full articulation, this tablet holder lets you swivel, rotate, and tilt your tablet to adjust the viewing angle and reduce neck strain while improving your ergonomic posture.
Portable Detachable Tablet Holder
The universal tablet stand comes with a detachable tablet holder. If you need to hold the tablet in your hands, simply detach the tablet holder from the stand and take the tablet with you.
STNDTBLTMOB is TAA compliant and backed by a 5-year StarTech.com warranty and free lifetime technical support.
  • Perfect for presentations
    This tablet stand on wheels enables you to use your tablet to deliver engaging presentations, while you stay focused on your audience and the content you're delivering. You can use your tablet as a visual cue or teleprompter, without having to hold it or repeatedly look down at it while you're speaking. With lockable casters and a strong base, this mobile tablet holder offers a great balance between mobility and stability, perfect for photography, videography, and educational environments.
  • Adjustable height and viewing angle
    The ergonomic tablet stand has a height adjustability range of 36.4" to 57.8" from the floor, so you can adjust it to your ideal height, whether you are sitting or standing. With full articulation, this tablet holder lets you swivel, rotate, and tilt your tablet to adjust the viewing angle and reduce neck strain while improving your ergonomic posture.
  • Portable detachable tablet holder
    The universal tablet stand features a detachable tablet holder. If you need to hold the tablet in your hands, simply detach the tablet holder from the stand and take the tablet with you.
  • Stability
    Designed for stability this cart features a stable base with 4 durable lockable casters. Casters can be locked and unlocked by pedal. Ideal for video conference calls, health care, and educational environments.
  • Easy setup
    This rolling ergonomic tablet stand is easy to assemble and only requires one tool. Portable detachable tablet holder with adjustable clamp holds and grips tablet on both sides to prevent it from sliding off.
StarTech.com Mobile Tablet Stand w/ Lockable Wheels, Height Adjustable Cart, Universal Rolling Floor Stand for Tablets from 7-11in, Portable Tablet Stand w/ Detachable Tablet Holder, TAA - Ergonomic Tablet Stand cart - for tablet
Cart
50 cm x 50 cm x 160 cm
Adjustable Height
92.5-146.8 cm
Tilt
280°
Lift
54.3 cm
Rotation
360°
Swivel
360°
Adjustments
Height, swivel, rotation, tilt
Recommended Use
Tablet
Recommended Display Size
7"-11"
Max Load Weight
900 g
Wheels Qty
4
Package Content
Base, 4 x casters, telescopic pole assembly, tablet holder, pole mounting screw
5-year warranty
50 cm
50 cm
160 cm
Adjustable Height
92.5-146.8 cm
Package Content
AV Furniture
Cart
Recommended Use
Tablet
7"-11"
Tilt
280°
Lift
54.3 cm
Rotation
360°
Swivel
360°
Adjustments
Max Load Weight
900 g
Wheels Qty
4
Brakes Qty
4
Dimensions & Weight Details
32 cm x 11 cm x 79 cm
Limited warranty - 5 years
GJK1 StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.69
GJK1 StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £10.01
GJK1 StarTech.com 2 m / 6.6 ft USB C Cable – Black In Stock £10.66
