Encourage collaboration and interactive classrooms with this StarTech.com mobile standing desk.
These sit-stand workstations allow users to create a setup that suits their needs. The adjustable carts can easily go from a sitting position to a standing position with no disruptions. The two front casters can be locked in place to prevent the rolling workstations from moving.
Simple Height Adjustments
Moving between sitting and standing throughout the day brings many health benefits, from increased circulation to reduced fatigue. The ergonomic sit-stand workstations make it easy for users to change their positioning, keeping them attentive and focused.
Adjust the desk to any height between 29" (740 mm) and 45" (1150 mm), using the one-touch lever. There are no preset heights, so each user can find the precise height they need to work most comfortably.
Large Work Surface
The large surface area of the desktop, 24" (600 mm) x 31.5" (800 mm), provides ample room for a laptop, mouse and more.
Perfect for Customizable Classrooms
Teachers can create dynamic learning environments to accommodate different needs. They simply need to unlock the two front casters and move the workstations around the classroom for:
- Personalized one-on-one learning
 - Presentations
 - Standard (or distanced) classroom configurations for lectures and tests
The portable desk can also be used in office training rooms, warehouses and manufacturing sites, home offices and IT departments.
STSCART2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Full product details at: https://www.startech.com/en-gb/display-mounting-ergonomics/stscart2
Mobile standing desk
Portable sit-stand cart is easily movable & fosters a productive workplace/learning environment; stable base with heavy-duty casters that can be locked (front only) with foot pedal. -
Large sturdy surface
Rolling sit-stand desk with wheels has a large black surface (24x31.5"); unassisted lift capacity of 11lb (5kg) & max static weight of 66lb (30kg); easily wiped clean. -
Height adjustable
Easily lift the worksurface of the ergonomic laptop computer desk to standing position with the one-touch lever-controlled adjustable height ranging 29" to 45" from the floor. -
Thoughtful design
Surface has beveled edge to relieve pressure on forearms; lever positioned to prevent accidental height adjustments; V-shaped base for more foot room; incl. required setup tools.
 - StarTech.com Mobile Standing Desk, Portable Sit Stand Ergonomic Height Adjustable Cart on Wheels, Rolling Computer/Laptop Workstation Table with Locking One-Touch Lift for Teacher/Student - Mobile Sit Stand Desk (STSCART2) - sit/standing desk - black
- Product Type
 - Sit/standing desk - mobile
- Top Surface
 - Black
- Base
 - Black
 - 75 cm - 120 cm / electric height adjustment
 - 2 years
- Product Type
- Package Content
 - Wrench, hex key, screws
- Max Load Weight
 - 30 kg
- Adjustable Height
 - Yes (electric)
- Assembly Required
 - Heavy-duty casters, onehand lever mechanism, one-touch lift-and-lock mechanism, 4 lockable casters
Top Surface
- Material
 - Wood
 - Black
- Size
 - 60 cm x 80 cm
Base
- Material
 - Steel
 - Black
Components
- Details
 - 4 x caster , Gas lift height adjustment mechanism - up to 5 kg max load weight
 - 60 cm
 - 80 cm
 - 75 cm - 120 cm
 - 28.2 kg
- Shipping Width
 - 92.5 cm
- Shipping Depth
 - 74 cm
- Shipping Height
 - 26.5 cm
- Shipping Weight
 - 28.4 kg
 - RoHS
 - 2 years
