StarTech.com Mobile Sit Stand Workstation
Quicklinx: D9VVWS00 Mfr#: STSCART
Hurry, only 2 left in stock!
£244.51 ex VAT
£293.41 inc VAT
Increase student's comfort and productivity with mobile desks that feature easy height adjustment. Encourage interactive classrooms and engaged learning with StarTech.com mobile sit-stand workstations.
These sit-stand desks allow students to set up their learning environments to suit their needs. The workstations can easily be adjusted from a sitting position to a standing position with no disruptions to the class. Teachers can arrange and rearrange their classrooms according to their lessons, they can set up individual desks for tests or lectures, or group two or more desks together for projects. The two front casters can be locked in place to prevent the workstations from moving.
Moving between sitting and standing throughout the day brings many health benefits, from increased circulation to reduced fatigue. The sit-stand workstations make it easy for students to change their positioning throughout the day, keeping them attentive and focused. Giving students the freedom to stand when needed can also help to reduce anxiety and restlessness.
Students can adjust the desk to any height between 29.5" (750 mm) and 45" (1150 mm), they simply need to squeeze the lever located under the work surface, and then move the workstation up or down. The adjustment lever on the right side of the desktop can also be locked using the provided key, so that the height won't accidentally change if a student knocks the lever.
There are no preset heights, so each student can find the precise height they need to work most comfortably.
The large surface area of the desktop, 24" (600 mm) x 31.5" (800 mm), provides ample room for all schoolwork and supplies such as textbooks, pens, and other stationery.
For laptop configurations, the workstations feature cable clips that run down the column in order to help keep cables organized. The workstations can also be combined with monitor mounts to add displays. The work surface also provides enough room for a keyboard and mouse.
Note: If more than 10 lb. (4.5 kg) of weight is added to the work surface, some manual force will be needed to raise the desktop.
Teachers can create dynamic environments to accommodate different needs. They simply need to unlock the two front casters and move the workstations around the classroom to: Split students into groups for projects; Pull individuals aside for personalized one-on-one learning; Sit the students in a circle for presentations and to encourage group conversations; Set up a standard classroom configuration for lectures and tests.
Teachers can also use the workstations for presentation purposes. The mobile workstations are ideal for moving around from class to class with laptops and other tools, and the height can be adjusted and locked.
The portable desks can also be used in the following settings: Office training rooms; Warehouses and manufacturing sites where workstations are shared amongst many individuals and need to be moved between different testing areas; Home offices; IT departments as server crash carts.
  • Mobile standing desk
    Portable sit-stand cart is easily movable & fosters a productive workplace/learning environment. Stable base (23x28") with heavy-duty casters that can be locked with foot pedal.
  • Large sturdy surface
    Rolling sit-stand desk has a large gray surface (24x31.5") with an unassisted lift capacity of 10lb (4.5kg) and a max static weight capacity of 110lb (50kg). Easily wiped clean.
  • Height adjustable
    Easily lift the worksurface of the ergonomic laptop computer desk to standing position with the one-touch lever-controlled adjustable height of 31.75" to 45" from the floor.
  • Lockable height setting
    The adjustment lever can be locked using incl. key to prevent any accidental height adjustments. Ideal for teachers/students in classrooms where safety measures are important.
  • Tidy workstation
    Route your cables down through the cable clips that can be installed along a track on either side along the column helping to keep your stand-up desk on wheels workspace organized.
StarTech.com Mobile Standing Desk, Portable Sit Stand Ergonomic Height Adjustable Cart on Wheels, Rolling Computer/Laptop Workstation Table w/ Locking One-Touch Lift for Teachers/Student - Mobile Computer Table (STSCART) stand - for notebook / keyboard / mouse - black & silver
Stand
70.4 cm x 11.5 cm x 58.6 cm
Adjustable Height
75-115 cm
Adjustments
20.5 kg
Recommended Use
Notebook / keyboard / mouse
Max Load Weight
50 kg
Black & silver
Package Content
Cable clips, column, casters, 8 x M6x15 round-head screws, 12 x M6x15 flat-head screws, M5 hex key, M4 hex key, 2 x locking casters
P/N: ARMTBLTDT, ARMTBLTIW, ARMTBLTUGN
70.4 cm
11.5 cm
58.6 cm
Adjustable Height
75-115 cm
20.5 kg
Black & silver
Package Content
AV Furniture
Stand
Recommended Use
Adjustments
Max Load Weight
50 kg
Dimensions & Weight Details
Dimensions
Worksurface - width: 60 cm, depth: 80 cm
D9VV StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £64.93
D9VV StarTech.com Articulating Monitor Arm In Stock £121.96
D9VV StarTech.com Tablet Stand - Desk/Wall Mount In Stock £27.26
D9VV StarTech.com Desk Mountable Tablet Stand In Stock £96.07
D9VV StarTech.com Mobile TV Cart, Portable/Rolling TV Stand 37-70" In Stock £293.78
D9VV StarTech.com Mobile Workstation Cart In Stock £375.89
