StarTech.com Mobile Projector and Laptop Stand / Cart
Quicklinx: GFGQWS00 Mfr#: ADJPROJCART
10 In Stock
£52.66 ex VAT
£63.19 inc VAT
Portable Projector Cart with Laptop Tray Height Adjustable Cable Management. This all-steel projector and laptop stand enables you to setup a mobile multimedia workstation that you can easily move between classrooms, boardrooms, and conference rooms. It has two device platforms that each support 22lb (10kg). This rolling cart is equipped with durable casters (2 lockable) that provide ease of transportation.
Setup Flexibility
With the two integrated device trays, this mobile projector trolley adjusts to your needs letting you choose where to mount your projector, laptop, and other media devices. Both trays have safety ledges that help prevent your equipment from sliding.
The upper tray has surface area of 13.8"x11.8" and lets you setup a laptop or projector depending on your needs. You can adjust its height (37.4" to 57" from the floor) and tilting angle (+/-12°) to provide a better viewing experience that will adjust to your presentation needs. Adjustments can be made by hand via the rotary knob locks.
The lower tray has a surface of 14.4"x11.8" and it sits at 27" from the floor.
Security and Stability
With a base area of 17.9"x19.7", this AV projector will comfortably support a combined load of 20 kg. For added security, you can keep your devices in place by running straps through the thin openings of the top and bottom trays (straps not included). Additionally, this cart comes with 2 cable management clips that will let you run your cables through the pole in a tidy and safe manner; and help with the transportation of your setup.
ADJPROJCART is backed by a StarTech.com 5-year warranty and free lifetime technical support.
  • Mobile projector and laptop stand
    This heavy-duty mobile cart provides 2 shelves (at different heights) that each support 22lb (10kg). Durable rolling projector cart has a strong/sturdy base (17.9" x 19.7"/45.5cm x 50.2cm) with lockable casters/wheels.
  • Height adjustable top tray
    Ventilated top shelf with a surface of 13.8" x 11.8" (35cm x 30cm); +/-12° Tilt by hand. Height is adjustable from 37.4"-57" (95cm to 145cm) from the floor via hand adjustable knobs.
  • Bottom tray
    Ventilated tray helps keep media devices cool. Has a surface of 14.3" x 11.8" (36.3cm x 30cm) and it sits at 27" (68.5cm) tall.
  • Flexible setup
    Setup a presentation workstation with a projector and laptop to easily transport the trolley between classrooms, boardrooms/conference rooms. Arrange your projector and laptop/notebook computer on either shelf depending on your setup needs.
  • Secure & organize devices
    Portable projector stand with sturdy platforms that have safety ledges to keep devices in place. Thin openings can be used to run straps to secure devices (straps not incl). Includes 2x cable management clips can be attached along pole.
StarTech.com Mobile Projector and Laptop Stand/Cart, Heavy Duty Portable Projector Stand (2 Vented Shelves, hold 22lb/10kg each), Height Adjustable Rolling AV Presentation Cart with Wheels - Lockable Casters cart - for projector / notebook - black
Cart
45.5 cm x 50.2 cm x 150 cm
Tilt
-12° to 12°
Adjustments
Height, tilt
10.6 kg
Recommended Use
Projector / notebook
Max Load Weight
20 kg
Material
Steel
Wheels Qty
4
Package Content
Hex key, wrench, 8 x nuts, 4 x M6 x 12 mm screws, 2 x cable clips, projector platform, laptop platform, support pole, base cross member, 2 x base feet, 5 x M6 x 65 mm bolts, 9 x washer (Type 1), 2 x M6x30 screws, 3 x M6 X 50 screws (type 1), washer (type 2), M6 X 50 screws (type 2), 2 x casters with brakes, 2 x casters with out brakes, 3 x knobs, 2 x mounting brackets
5-year warranty
45.5 cm
50.2 cm
150 cm
10.6 kg
Material
Steel
Package Content
AV Furniture
Cart
Recommended Use
Shelf Qty
2
Cable Management
Integrated cable management
Tilt
-12° to 12°
Adjustments
Height, tilt
Max Load Weight
20 kg
Wheels Qty
4
Brakes Qty
2
Dimensions & Weight Details
Dimensions
Cart - width: 45.5 cm, depth: 50.2 cm, height: 150 cm , Top shelf - width: 35 cm, depth: 30 cm , Bottom shelf - width: 36.3 cm, depth: 30 cm
40 cm x 35.5 cm x 11 cm / 10.6 kg
Limited warranty - 5 years
GFGQ StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
GFGQ StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
GFGQ StarTech.com Rolling TV Cart/Portable Mount In Stock £438.07
