Allows the use of older Mini USB cables with newer Micro USB devices.
The UUSBMUSBMF Micro USB to Mini USB 2.0 Adapter features a Micro USB male (B-type) connector and a Mini USB female connector - a cost-effective and convenient solution that lets you use older Mini USB cables to sync and charge newer Micro USB devices such as BlackBerry or Android-based cell phones.
Providing both versatility and durability, the Micro USB to Mini USB adapter saves you from having to carry multiple cables to accommodate different types of USB device connection (Micro USB/Mini USB).
- StarTech.com Micro USB to Mini USB 2.0 Adapter M/F - Micro to Mini USB Adapter - Mini USB Adapter - Micro USB to Mini USB (UUSBMUSBMF) - USB adapter - Micro-USB Type B to mini-USB Type B
- USB adapter
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- Mini-USB Type B - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB2HABM1M, USB2HABM2M, USB2HABM50CM, USB2HABM6IN, USB2HABMY1, USB2HABMY3, USB2HABMY6, USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
- USB adapter
- Black
- Connector
- RoHS
- Designed For
