StarTech.com Mini USB Bluetooth 4.0 Adapter 10m (33ft) Class 2 EDR Wireless Dongle
Quicklinx: 9J4JWS00 Mfr#: USBBT2EDR4
  • Bluetooth 4.0
Add Bluetooth 4.0 capabilities to a laptop or desktop computer through USB. The USBBT2EDR4 Class 2 USB Bluetooth 4.0 Adapter lets you add Bluetooth wireless capabilities to a laptop or desktop computer through USB, with support for transfer distances of up to 10m (33ft).
This Bluetooth adapter is based on the well-established Broadcom 20702 chip, offering reliable throughput and Packet Loss Concealment (PLC) technology which reduces errors / dropped connections and improves audio performance.
Compliant with Bluetooth 4.0 LE +EDR, the USB Bluetooth adapter offers data transfer rates up to 3 Mbps and low power consumption. This Bluetooth Smart Ready transceiver is an effective way to connect to a rapidly growing list of the Bluetooth Smart peripherals on the market, including the latest Apple and Android smartphones and tablets, headsets or monitoring equipment. Bluetooth v4.0 also integrates added security for all transfers using 128-bit AES encryption.
A conveniently portable device, this ultra-compact adapter is unobtrusive when connected to your laptop, so you won't have to remove it each time you store your laptop in a carrying case or bag. The adapter is also backward compatible with previous Bluetooth standards (v3.0, 2.x, and 1.x) to ensure connectivity with all of your Bluetooth devices.
StarTech.com Mini USB Bluetooth 4.0 Adapter - 10m (33ft) Class 2 EDR Wireless Dongle - USB Bluetooth Dongle - Bluetooth Smart Ready LE+EDR (USBBT2EDR4) - network adapter - USB
Network adapter
External
Interface (Bus) Type
USB
1.5 cm x 0.6 cm x 1.9 cm
3 g
Bluetooth 2.1 EDR, Bluetooth 4.0
Bluetooth Class
Class 2
Data Transfer Rate
3 Mbps
Frequency Band
2.4 GHz
Bluetooth 2.1, Bluetooth 4.0
Microsoft Windows Server 2003, Apple MacOS X 10.8 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB
Bluetooth Class
Class 2
Data Transfer Rate
3 Mbps
Line Coding Format
GFSK, 8 DPSK
Frequency Band
2.4 GHz
Max Range Open Space
10 m
Status Indicators
Power, standby
USB powered
Aerial
Antenna
Internal
FCC, RoHS
1.5 cm
0.6 cm
1.9 cm
3 g
-10 °C
50 °C
0 - 90%
9J4J StarTech.com Mini USB Bluetooth 2.1 Adapter Class 1 EDR Wireless Network Adapter In Stock £13.29
9J4J StarTech.com Mini USB Bluetooth 4.0 Adapter 50m (165ft) Class 1 EDR Wireless Dongle In Stock £17.54
