Add Bluetooth 2.0 with EDR capabilities to a computer, through USB. The USBBT2EDR2 USB to Class 2 Bluetooth Adapter with EDR is a micro-sized adapter that adds Bluetooth capabilities to a computer through an available USB port, which enables you to connect to devices wirelessly, at ranges up to 20m (65ft) while consuming minimal power. Supporting the Bluetooth v2.1 specification along with Enhanced Data Rate (EDR), for transfer rates up to 3 Mbps, this adapter uses a small form factor design that makes it conveniently portable and unobtrusive when connected to a computer.
- StarTech.com Mini USB Bluetooth 2.1 Adapter - Class 2 EDR Wireless Network Adapter - network adapter - USB
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 1 cm x 2 cm x 0.6 cm
- 2 g
- Data Link Protocol
- Bluetooth 2.1 EDR
- Bluetooth Class
- Class 2
- Data Transfer Rate
- 3 Mbps
- Frequency Band
- 2.4 GHz
- Bluetooth 2.1
- Black
- System Requirements
- Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB
- Connectivity Technology
- Wireless
- Bluetooth 2.1 EDR
- Bluetooth Class
- Class 2
- 3 Mbps
- Line Coding Format
- DQPSK, GFSK, 8 DPSK
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 20 m
- Status Indicators
- Power, standby
- USB powered
- Bluetooth 2.1
Aerial
- Antenna
- Internal
- Connections
- 1 x USB - 4 pin USB Type A
- FCC, RoHS
- Black
- OS Required
- 1 cm
- 2 cm
- 0.6 cm
- 2 g
- Limited warranty - 2 years
- -10 °C
- 50 °C
