Brand
StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F
Quicklinx: 6BCMWS00 Mfr#: MDVIHDMIMF
Length: 20cm
Hurry, only 3 left in stock!
£13.58 ex VAT
£16.29 inc VAT
This Mini DVI to HDMI Adapter cable features one 32 pin mini-DVI Male and one HDMI Female connector, allowing the video signal from a mini DVI equipped device to be output to an HDMI equipped TV set or A/V Receiver.
This is the perfect solution for using your HDTV instead of a computer monitor, or watch movies directly on your TV from your Apple MacBook or iMac Computer.
MDVIHDMIMF will not work with the current MacBooks, it is made for MacBooks that use mini DVI connectors
StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F - MacBook Mini DVI Adapter - Mini DVI to HDMI Cable (MDVIHDMIMF) - adapter - HDMI / DVI - 20 cm
Cable
Adapter - HDMI / DVI
Length
20 cm
White
Connector
Mini-DVI - male
Connector (Second End)
HDMI - female
P/N: HDMIROTMM6
Cable Type
Adapter
Interface Supported
HDMI / DVI
Length
20 cm
White
Connector
Apple mini-DVI - male
19 pin HDMI Type A - female
Limited warranty - lifetime
P/N: HDMIROTMM6
Length: 20cm
