Connect an HDMI -capable display to a Mini-DisplayPort -equipped PC or Mac computer. The MDP2HDW passive Mini DisplayPort to HDMI Video Adapter/Converter (White) offers a convenient HDMI/Mini-DisplayPort link, which enables you to connect an HDMI computer monitor or television to a device with a Mini-DisplayPort output, while saving the expense of upgrading the monitor for compatibility.
The adapter supports high resolution output up to 1920x1200, offering a high quality solution for mirroring or extending a computer desktop onto a second display.
This versatile Mini DisplayPort to HDMI adapter requires a multimode DisplayPort port (DisplayPort ++) connection to function, and is compatible with Intel Thunderbolt output when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter allows for audio pass-through if supported by the video source. Please review the video source manual to confirm support.
- StarTech.com Mini DisplayPort® to HDMI® Video Adapter Converter 1920x1200 - White Mini DP to HDMI Adapter M/F (MDP2HDW) - adapter - DisplayPort / HDMI - 17 cm
- Cable
- Adapter - DisplayPort / HDMI
- Length
- 17 cm
- White
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - female
- 3-year warranty
- Cable Type
- Adapter
- Interface Supported
- Length
- 17 cm
- White
- Connector
- 19 pin HDMI Type A - female
- FCC, RoHS
- Limited warranty - 3 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.49 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter | In Stock | £11.67 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £23.21 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £10.59 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.52 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.88 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £26.05 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £35.34 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £23.91 |
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter | In Stock | £18.78 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £20.14 |
StarTech.com DP to HDMI or VGA Converter | In Stock | £18.68 |
StarTech.com Mini DisplayPort to HDMI Adapter - 1080p | In Stock | £11.86 |
