StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 5m
Quicklinx: C9W7WS00 Mfr#: MDP2HDMM5MB
More than 50 In Stock
£19.03 ex VAT
£22.83 inc VAT
Eliminate clutter by connecting your mDP computer directly to an HDMI display, using this 5-meter cable. This 5-meter (15 ft.) Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable works with your 4K HDMI display and video source to ensure you it maintains it's astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 5 m in length, this adapter cable delivers a direct connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, a 1-meter mDP to HDMI cable (MDP2HDMM1MB), a 2-meter mDP to HDMI cable (MDP2HDMM2MB), and a 3-meter mDP to HDMI cable (MDP2HDMM3MB) enable you to choose the right cable length for your custom installation needs.
  • Astonishing picture quality
    This adapter cable works with your 4K HDMI display and video source to ensure you it maintains it's astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
  • Hassle-free setup
  • Clutter-free installation
    At 5 m in length, this adapter cable delivers a direct connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, we also offer a 1-meter mDP to HDMI cable (MDP2HDMM1MB), a 2-meter mDP to HDMI cable (MDP2HDMM2MB), and a 3-meter mDP to HDMI cable (MDP2HDMM3MB), enabling you to choose the right cable length for your custom installation needs. The MDP2HDMM5MB is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com Mini DisplayPort to HDMI Adapter Cable - mDP to HDMI Adapter with Built-in Cable - Black - 5 m (15 ft.) - Ultra HD 4K 30Hz (MDP2HDMM5MB) - adapter cable - DisplayPort / HDMI - 5 m
Cable
Adapter cable - DisplayPort / HDMI
Length
5 m
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.2
4K support
3-year warranty
Cable Type
Adapter cable 4K support
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
5 m
HDCP compliant, DPCP compliant
Connector
19 pin HDMI Type A - male
FCC, RoHS
Limited warranty - 3 years
C9W7 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £10.84
C9W7 StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.77
C9W7 StarTech.com 6ft mDP to HDMI cable - 4K In Stock £13.79
C9W7 StarTech.com 3ft mDP to HDMI cable - 4K In Stock £13.49
C9W7 StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 3m In Stock £15.15
C9W7 StarTech.com Mini DisplayPort to HDMI Cable - 4K 30Hz - 5m In Stock £19.03
C9W7 StarTech.com Mini DisplayPort to HDMI Adapter - 1080p In Stock £11.43
