StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio
Quicklinx: 76MQWS00 Mfr#: MDP2HDMIUSBA
Connect an HDMI display to a Mini-DisplayPort source with audio.
The MDP2HDMIUSBA Mini DisplayPort with USB Audio to HDMI Adapter offers a cost-effective HDMI with audio to Mini DisplayPort link, letting you connect an HDMI-capable HDTV to a device with a Mini DisplayPort output, while saving the expense of upgrading the TV for compatibility. Simply plug in the USB and Mini DisplayPort connectors to a PC or Mac and the HDMI connector to an HDMI television/monitor. 2-channel analog audio will pass through to the HDMI connection, delivering sound to the display side, with the convenience of one HDMI cable. MDP2HDMIUSBA is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
  • Versatile connectivity
    This Mini DisplayPort to HDMI Adapter with USB Audio offers a three-in-one solution for connecting a PC or Mac to an HDMI display, while also providing a USB audio interface and USB power.
  • High-quality video output
    Supports resolutions up to 1920 x 1200, allowing users to enjoy crisp, clear video quality when streaming media, sharing content, or delivering presentations.
  • Easy to use
    The adapter features a Plug-and-Play design with no software installation required, making it easy for users to connect their devices and start sharing content immediately.
  • Durable design
    Constructed with a 60 cm cable and compliant with RoHS standards, this adapter is designed for both durability and environmental responsibility.
StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio - Mini DP to HDMI (MDP2HDMIUSBA) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
16.2 cm x 5.6 cm x 1 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x USB - 4 pin USB Type A - male
LED indicator, USB powered, USB audio interface, HDCP
1 x video / USB cable - 60 cm
RoHS
16.2 cm
5.6 cm
1 cm
90 g
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
0 - 80%
76MQ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
76MQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
76MQ StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
76MQ StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £10.84
76MQ StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £9.00
76MQ StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £19.03
