Extended Cable - 1080p - Thunderbolt 1 & 2 Compatible
This Mini DisplayPort to HDMI adapter lets you connect your mDP computer to an HDMI, television, projector or monitor.
Extended Cable Length
This Mini DP to HDMI adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands.
HD Picture Quality
With support for video resolutions up to 1080p, you'll be surprised at the picture spectacular picture quality this adapter provides. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition.
Ultimate Portability
This mDP video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag while commuting between your home, office or traveling for business.
The MDP2HDEC is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Extended cable length
This Mini DP to HDMI adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands. -
HD picture quality
With support for video resolutions up to 1080p, you'll be surprised at the picture spectacular picture quality this adapter provides. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition. -
Ultimate portability
- StarTech.com Mini DisplayPort to HDMI Adapter, mDP to HDMI Adapter Dongle, 1080p, Mini DisplayPort 1.2 to HDMI Monitor/Display, Mini DP to HDMI Video Converter, 12" Long Attached Cable - Thunderbolt 1/2 Compatible (MDP2HDEC) - adapter - Mini DisplayPort / HDMI - 30 cm
- Cable
- Adapter - Mini DisplayPort / HDMI
- Max Output Resolution
- 1920 x 1200 - 60 Hz
- Length
- 30 cm
- Black
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - female
- Displayport 1.2/Thunderbolt 2
- Passive converter
- 3-year warranty
- Cable Type
- Adapter passive converter
- Interface Supported
- Length
- 30 cm
- 7.1 channel Surround Sound
- Black
Adapters & Converters
- 1920 x 1200
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Ubuntu, Google Chrome OS, Windows 10
- Connector
- 19 pin HDMI Type A - female
- HDCP 1.4
- 2.65 cm
- 1.5 cm
- 24 g
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Weight
- 25 g
- Limited warranty - 3 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.60 |
