StarTech.com Mini DisplayPort to HDMI - 4K
Quicklinx: CGVNWS00 Mfr#: MDP2HD4K60S
15 In Stock
£21.91 ex VAT
£26.29 inc VAT
Connect your mDP computer to an HDMI display using this converter, which supports UHD resolutions up to 4K at 60Hz. This Mini DisplayPort to HDMI adapter lets you output HDMI video and audio from an mDP device, with support for Ultra HD 4K at 60Hz.
The adapter lets you harness the video capabilities that are built into your Mini DisplayPort connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while using multiple monitors to work on resource-demanding applications.
Unlike many 4K Mini DisplayPort to HDMI adapters that only support a 30Hz refresh rate, this adapter works with HDMI 2.0 displays that can deliver output resolutions of up to 3840 x 2160p at 60Hz. Support for HDMI 2.0 means this adapter can support bandwidth up to 18Gbps, making it an ideal solution for performing high-resolution tasks such as editing 4K video.
The adapter is backward compatible with 1080p displays, which ensures compatibility with lower resolution displays such as TVs or projectors around your home or office.
The compact video adapter is highly portable and lightweight. It's the perfect accessory for your portable mDP devices, fitting easily into your laptop bag or carrying case.
The portable adapter is the perfect accessory for deployment with company computers, enabling your employees to interface with BYOD (Bring Your Own Device) HDMI applications around the office, such as working at a hot-desk with an HDMI display or sharing your laptop's screen on a boardroom projector.
To ensure compatibility with any Mini DisplayPort output, the mDP adapter offers active conversion. Active video conversion is required to maintain 4K resolutions when converting Mini DisplayPort to HDMI. An active mDP adapter is also ideal for outputting 1080p resolutions by ensuring compatibility with graphics cards that are not capable of outputting multi-mode DP++ signals, such as ATI Eyefinity cards.
For a hassle-free setup, the Mini DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers.
Note: To achieve 4K resolution at 60 Hz a DisplayPort 1.2 output and an HDMI 2.0 display are required.
  • Astonishing picture quality with support for Ultra HD 4K at 60 Hz
    The adapter lets you harness the video capabilities that are built into your Mini DisplayPort connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while using multiple monitors to work on resource-demanding applications. Unlike many 4K Mini DisplayPort to HDMI adapters that only support a 30Hz refresh rate, this adapter works with HDMI 2.0 displays that can deliver output resolutions of up to 3840 x 2160p at 60Hz. Support for HDMI 2.0 means this adapter can support bandwidth up to 18Gbps, making it an ideal solution for performing high-resolution tasks such as editing 4K video. The adapter is backward compatible with 1080p displays, which ensures compatibility with lower resolution displays such as TVs or projectors around your home or office.
  • Ultimate portability with a compact, lightweight design
    The compact video adapter is highly portable and lightweight. It's the perfect accessory for your portable mDP devices, fitting easily into your laptop bag or carrying case. The portable adapter is the perfect accessory for deployment with company computers, enabling your employees to interface with BYOD (Bring Your Own Device) HDMI applications around the office, such as working at a hot-desk with an HDMI display or sharing your laptop's screen on a boardroom projector.
  • Hassle-free setup with an active adapter that features plug-and-play installation
    To ensure compatibility with any Mini DisplayPort output, the mDP adapter offers active conversion. Active video conversion is required to maintain 4K resolutions when converting Mini DisplayPort to HDMI. An active mDP adapter is also ideal for outputting 1080p resolutions by ensuring compatibility with graphics cards that are not capable of outputting multi-mode DP++ signals, such as ATI Eyefinity cards. For a hassle-free setup, the Mini DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers. Note: To achieve 4K resolution at 60 Hz a DisplayPort 1.2 output and an HDMI 2.0 display are required. The MDP2HD4K60S is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech Mini DisplayPort to HDMI Adapter - 4K mDP to HDMI Converter - UHD 4K 60Hz (MDP2HD4K60S) - video converter
Video converter
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
3-year warranty
Video converter
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
Plug and Play, FCC, RoHS, WEEE, RCM, DisplayPort 1.2, HDCP 2.2
Limited warranty - 3 years
5 °C
35 °C
CGVN StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £10.84
CGVN StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £19.03
CGVN StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.51
CGVN StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
CGVN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
CGVN StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
CGVN StarTech.com Mini DisplayPort to HDMI - 4K In Stock £21.91
CGVN StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
CGVN StarTech.com DP to HDMI Adapter with HDR In Stock £25.85
CGVN StarTech.com Mini DisplayPort to HDMI Adapter - 1080p In Stock £10.81
