StarTech.com Mini DisplayPort to DVI Video Adapter Converter
Quicklinx: 6LCLWS00 Mfr#: MDP2DVI
More than 50 In Stock
£9.25 ex VAT
£11.10 inc VAT
Connect a DVI display to a Mini DisplayPort equipped PC or MAC . The StarTech.com MDP2DVI Mini DisplayPort DVI Adapter Cable offers a cost-effective DVI/Mini DisplayPort link, letting you connect a DVI computer monitor to a device with a Mini DisplayPort output while saving the expense of upgrading the monitor for compatibility. MDP2DVI is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
  • Durable construction
    Built with high-quality materials, this adapter ensures longevity and reliable performance, making it suitable for everyday use.
  • Compact design
    The lightweight and small form factor of this adapter makes it easy to carry and use, perfect for traveling professionals.
  • Wide compatibility
    This adapter is designed to work with Mini DisplayPort devices, offering versatility for both MacBook and PC users.
StarTech.com Mini DisplayPort to DVI Adapter - 1920x1200 – Thunderbolt 2 – mDP to DVI Converter for Your Mini DP MacBook or PC (MDP2DVI) - DVI adapter - 10.2 cm
DVI adapter
Length
10.2 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-I - female
FCC, RoHS
3-year warranty
P/N: DP2MDPMF3, DP2MDPMF6IN, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
DVI adapter
Length
10.2 cm
Connector
24+5 pin combined DVI - female
FCC, RoHS
3-year warranty
6LCL StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
6LCL StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.25
6LCL StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £22.12
6LCL StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £7.80
6LCL StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.88
6LCL StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.03
6LCL StarTech.com mDP to Dual-Link DVI Adapter In Stock £17.91
