StarTech.com Mini DisplayPort to DVI Dual-Link Active Adapter – USB Powered
Quicklinx: 7NZLWS00 Mfr#: MDP2DVID
  • DisplayPort
Connect your Mini DisplayPort video source to a DVI-D display.
The MDP2DVID Mini DisplayPort to DVI-D Dual-Link adapter lets you connect your Mini DisplayPort video source (Macbook, Macbook Pro, Macbook Air, etc.) to any DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor. The Mini DisplayPort adapter offers an active conversion, which is powered by a single USB port and is able to handle full dual-link resolutions (up to 2560x1600). Use it to mirror your display to another monitor, or extend your desktop to increase your workspace.
StarTech.com Mini DisplayPort to DVI Dual-Link Active Adapter - USB Powered - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
2560 x 1600
1 x DisplayPort input - Mini DisplayPort , 1 x DVI-D output - 24+1 pin digital DVI , 1 x USB - 4 pin USB Type A
16 cm x 20.8 cm x 1.2 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
2560 x 1600
1 x DisplayPort input - Mini DisplayPort - male , 1 x DVI-D output - 24+1 pin digital DVI - female , 1 x USB - 4 pin USB Type A - male
USB powered
Video Output
Supported Display Graphics
WUXGA (1920 x 1200), 2560x1600
FCC, RoHS
16 cm
20.8 cm
1.2 cm
119 g
Enclosure Colour
Limited warranty - 3 years
70 °C
10 - 85% (non-condensing)
7NZL StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
7NZL StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £22.80
7NZL StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
7NZL StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
7NZL StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
7NZL StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.08
