The MDP2DVIS Mini DisplayPort to DVI Active Adapter (single-link) lets you connect your Mini-DisplayPort video source to a DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort capable monitor.
Unlike passive video adapters, this Mini DisplayPort to DVI adapter offers an active conversion for use with any Mini DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
Supporting resolutions up to 1920x1200, this compact device provides a simple solution for adapting PC or Mac Mini-DisplayPort output for DVI monitors, televisions or projectors.
The Mini DP to DVI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
- StarTech.com Mini DisplayPort to DVI Adapter - 1080p - Single Link - Active - Mini DP (Thunderbolt) to DVI Monitor Adapter (MDP2DVIS) - DVI adapter - 20 cm
- DVI adapter - dual link
- HDCP compliant
- Length
- 20 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - female
- FCC, RoHS
- Black
- 3-year warranty
- DVI adapter
- TMDS Links
- Dual link
- HDCP compliant
- Length
- 20 cm
- Black
- Connector
- 24+1 pin digital DVI - female
- DisplayPort 1.1, FCC, RoHS
- 3-year warranty
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £23.80 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £9.88 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.79 |
StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black | In Stock | £8.16 |
